Basic SERT Question.
Old Nov 19, 2007 | 11:17 AM
Herr Monk's Avatar
Herr Monk
Default Basic SERT Question.
I'm getting my SERT today. Found a new one cheap online.It's part # 32107-01G. Now while the fellow I bought it off, bought it from the dealer, for an '08 he special ordered (then canceled) I'm hearing that I need to get the "J" softwear to get the maps that use the 02 sensors. Is that correct?
I also understand I need to wiring. Once it comes in I will head down to the stealer and pick those up.
Can someone give me just a general discription of how setup and install of this thing goes? Is it a "project"?
Also, I currently have the flash Stage I download, and want to richen it. I have a Big Sucker, and SEIIS. Anyone recommend a map?
Thanks. I'm new to EFI, so anyone familiar with the SERT, comments welcome.
Old Nov 19, 2007 | 11:54 AM
flynavy's Avatar
flynavy
Default RE: Basic SERT Question.
Why did you get the SERT, Monk?
Is the bike not running well? There could be reasons for that a SERT won't cure.
Old Nov 19, 2007 | 11:58 AM
thecabinboy's Avatar
thecabinboy
1.install program to computer
2.hook up cable to computer and module
3.hook other cable to module and bike
4.pick which map you want to send to bike
5.turn key switch to "on", set switch onhandlebars to "run"
6.program ECM (do not disturb cables or bike till it says it's finished
7.turn off key switch for 10 seconds
8.go for a test drive
The SERT is brand new in the box right? Once its been hooked to a bike its keyed to that bike forever.
Old Nov 19, 2007 | 11:59 AM
thecabinboy
Oh yea, be sure to print and read then reread the manual.
Old Nov 19, 2007 | 12:12 PM
Herr Monk's Avatar
Herr Monk
Brand new in box.
Got the SERT so I could tune my ride correclty. It's running lean, even with the stage I download it's lean.
Come spring I'm doing a high performance build, after which, I'll have it Dynod. SERT seemed, while not the easiest/cheapest, the best once I have everything done, and dynod.
Old Nov 19, 2007 | 12:16 PM
darkdyna06's Avatar
darkdyna06
I ran my 06 with the stg 1 download for quite a while then tried a PCIII which worked well until I went 95". The dyno shop ran my bike after the build with the PCIII removed, STG 1 flash only and it was dead rich everywhere except WOT, and that was with 9.5:1 compression, andrews 37 cams, and ported heads. You may not need to richen it up at all if it doesnt ping.
Old Nov 19, 2007 | 12:26 PM
Herr Monk's Avatar
Herr Monk
The Download I have was made for a more closed pipe than I am running, and, like the stock map, the canned "street legal" maps all keep it running lean.
I get popping at decel.
Old Nov 19, 2007 | 12:48 PM
Herr Monk's Avatar
Herr Monk
Nother question:
Can I change the rev. limiter with the race tuner? Right now it is set at 6.2k I think, with the stage I download. I don't want it back down at stock.
Will the SERT keep this? Allow me to ajust it? Or will it lock it back down to stock?
Thanks
Old Nov 19, 2007 | 01:18 PM
Herr Monk's Avatar
Herr Monk
Got it in...
Also, any recommendations for map # for my setup?
Thanks
Old Nov 19, 2007 | 01:25 PM
Chipstah's Avatar
Chipstah
ORIGINAL: Herr Monk
Brand new in box.
All good reasons - you'll be glad you got the SERT when you go to get it dyno'ed and if you ever make any future changes, until then it'll be helpful but perhaps not necessary.
