gloves - its cold here !
Old Dec 11, 2007 | 01:27 PM
matkiwi's Avatar
matkiwi
Default gloves - its cold here !
I have a long ride planned tomorrow in the cold ... thanks you all in texas and other places for the weather updates [:@] here in the UK its about 30F ... maybe 40 in the middle of the day. I'm heading to London and back (150 miles) over the next couple of days and none of my gloves are working at keeping my hands warm, tried scuba gloves and putting some rubber ones on under my leather HD gloves but nothing is working.
The weather is clear blue skies here so I really have to go on the bike ... but will stop at the local (non-HD) bike shop and pick up some gloves tomorrow on way ... any tips as to what type I should get ? ... or is there a cheap fix I can do ? ... don't really care how it looks ... I'm going to be wearing my full helmet already ...
appreciate any suggestions ... Mat
Old Dec 11, 2007 | 01:45 PM
WildBillAce2's Avatar
WildBillAce2
Default RE: gloves - its cold here !
I'd look for some good ski gloves at a sporting goods store.
Old Dec 11, 2007 | 01:57 PM
cadman311's Avatar
cadman311
Heated hand grips are so nice for riding. They will get so hot you would not touch them with out gloves.
Old Dec 11, 2007 | 02:20 PM
wiggy's Avatar
wiggy
I to am in the cold in the uk.
I use Vulkan made by IXS.
They are thermal lined & are made from Goretex soare warm & waterproof.
Picked them up from our local J&S last year - they were about ÂŁ80.00.
Old Dec 11, 2007 | 02:56 PM
Sec Super Glide's Avatar
Sec Super Glide
You can use those heat pads that construction workers use open the packadge and shake, I put mine in my pockets to start them going .
Old Dec 11, 2007 | 02:59 PM
ElConquistador's Avatar
ElConquistador
I have the heated HD gloves. The pigtail attached to the battery pretty quickly, and they keep my hands toasty well below freezing.
Old Dec 11, 2007 | 03:25 PM
lone rider's Avatar
lone rider
Colder than a witches tit up here in London. I wear Alpinestar sky gloves with thinsulate glove liners and i had to stop three times this morning on the way to work to warm myhands up, i only go 15 miles Sutton to Heathrow. Good Luck with your trip Matt.
Old Dec 11, 2007 | 03:36 PM
ElConquistador
You might also want to try putting the rubber gloves over the insulated gloves (rather than the other way around). The rubber on the outside will prevent cold air from leaking around the seams into the trapped air space that makes up the insulation of the gloves, and thus cut down on thermal transfer. It will also allow the lining of the insulated gloves to wick moisture away from your hands rather than build up between your skin and the rubber glove.
Old Dec 11, 2007 | 04:17 PM
hk_shooter's Avatar
hk_shooter
Good gauntlet style gloves with Gore-Tex linings, with a rubberized over-glove. or the chemical heat packs others suggested. Something windproof, to keep the cold air out and something to keep the warmth in(like Gore-Tex). Or if you plan to ride much, they make a "muff" or gauntlet type thing that attaches to the grips and your hands go insided them. Hard to explain...
Old Dec 11, 2007 | 04:34 PM
dirico1266's Avatar
dirico1266
I bought the HARLEY heated golves to ride in mass. I moved to az and when it's 40 I still use them. They are very warm.
I bought them on ebay for 100$.
