Hq 95
Old Jan 2, 2008 | 11:23 PM
mud's Avatar
mud
Default RE: HQ 95" question
ORIGINAL: clayman
Cool, thanks for the info Mud, I bet that is a fun scoot to be rippin arround on now. Mine is starting to feel slow to me, its time.
I had the evo build on hold for awhile i wasnt sure which way i wanted to go, i ended up getting it totally rebuilt. Its going back together right now, ive had the entire engine polished and the cylinders are powder coated black along with the spacer in the rocker boxes.
I have been renovating my shop so ive had no place to work so all projects were pilled into the corner of my basement. But its done now and im back at it, ive got some frame work to do. I will be getting the engine back in a couple of weeks so it should come together pretty quick now.
I thought HQ moved to the states, you meen theres actually a good performance company this side of the border
Anyways good talking wiht ya, i havnt been arround here much but have been popping in alot more lately.
More later
Welcome back Clay.
That motor looks a lot diffrent from the last pix you posted.
Keep us updated.
HQ worx from both sides of the Waterway there above Michigan.
mud
Old Jan 2, 2008 | 11:33 PM
clayman's Avatar
clayman
I was just checking there site out, youve got me thinkin, and that can get me in trouble.
Did you go gear drive.
Old Jan 2, 2008 | 11:49 PM
mud's Avatar
mud
ORIGINAL: clayman
Clay, I'm spinning em with the chain drive.
My research says there is not that much to gain
by going to a geardriven set of bumpsticks.
Doug's latest webtool is here -
http://www.head-quarters-usa.com/customtwin.html
Best to give him a call though.
The phone line is sometimes busy forever,
but it will be worth your while to keep trying.
He is a straight shooter.
He will not steer you wrong.
mud
Old Jan 2, 2008 | 11:55 PM
clayman's Avatar
clayman
Thanks again for the info and the welcome back Mud, that meens alot.
Ill keep you posted.
Clay
Old Jan 3, 2008 | 12:15 AM
mud's Avatar
mud
ORIGINAL: mentor70
Hey Mud, what is the part # on your CP piston box?
they offer 3 pistons based on a 85 CC head. a 9.5,10.1, and 10.5.
the dome volumes are 4cc, 9cc, and 12cc. respectively.
My heads are at 82 CCs now, and I have the 9.5 piston to get 10.1.
Your cams are chain drive?
dd, chain driven bumpstix.
Doug sent the 9cc domed for my 11:1 motor.
I do believe he calculates this along with the spindrop
equated along with the gasket thickness.
mud
Old Jan 3, 2008 | 12:48 AM
mentor70's Avatar
mentor70
I cant see the "spin drop" on your heads at all!
Is it there or not?
Last time I talked with doug he sounded like he might do away with that all together.
Old Jan 3, 2008 | 11:28 AM
mud's Avatar
mud
ORIGINAL: mentor70
Is it there or not?
Well I said I think he calculates this as so and so,
when I actually don't know exactly how he calculates this.
I don't think he tells exactly what all he does to anyone.
mud
Old Jan 3, 2008 | 04:13 PM
mentor70's Avatar
mentor70
If you call, he will tell you every thing about your build.
Im thinking your at 80ccs on the heads with that piston.
I have to use the SE BB gaskets with my heads, they have a .025 drop in them.
that leaves me a .030 quench.
If you used a .030 head gasket your probably right on the money!
Old Jan 3, 2008 | 10:22 PM
Crazy Canuck's Avatar
Crazy Canuck
That was the first thing I noticed when I got my
heads back from Doug a few weeks ago. I thought
that maybe he had forgotten to spin drop my heads.
I gave him a buzz and he explained that before, he
could not get thin enough head gaskets. So he needed
to spin drop. My head gaskets are .027, which eliminates
the need to spin drop.
BadHabit
Engine Mechanical Topics
20
Mar 5, 2019 04:01 PM
03Custom883
Nov 5, 2017 07:50 PM
hutch08
16
May 20, 2014 12:33 AM
FLHXXHLF
Mar 28, 2009 06:34 PM
schmeg
Exhaust System Topics
Nov 26, 2007 08:12 AM
