Lower slider removal question
Old Jan 12, 2008 | 10:10 AM
MovedtoSyracuse's Avatar
MovedtoSyracuse
Default Lower slider removal question
OK....so I've got my forks removed from the bike and laying on the garage floor. My question/confusing is this: the service manual takes you through totally disassembling the fork tubes and sliders. Is there a shortcut for just removing the lower slider?
Old Jan 12, 2008 | 10:24 AM
tombeving's Avatar
tombeving
Default RE: Lower slider removal question
I replaced the sliders on a 06 street bob for a friend of mine. I used the service manual, and it was a pretty easy swap. I would say use the manual.
Old Jan 12, 2008 | 10:57 AM
Muddyape's Avatar
Muddyape
I just did mine....I tried to do it without taking everything apart but seemed easier to just change my springs now instead of later like I was planning. Need to follow manual....no real short cut. I guess if you break the 12mm allen bolts free on bottom you could drain fluid that way, then take off dust caps, retaining clips and pull sliders. My only issue/concern is that if you dont remove top caps and relieve spring tension it might not allow you to do what you need or put assembly under tension while trying to disassemble.
flastreetglide
Dec 9, 2008 09:08 PM
toecat2000
Mar 17, 2008 06:32 PM
MovedtoSyracuse
Dec 26, 2007 04:08 PM
Muddyape
Dec 24, 2007 01:08 PM
lemhead16
Mar 21, 2007 09:56 PM
