Clarification on oils!
https://www.hdforums.com/m_601136/tm.htm
"Looking at these ranges we notice that 50w engine oil is the same ârealâ viscosity as 90w gear oil. So it stands to reason that they might be substituted for each other. But remember that there are other factors involved than just viscosity. The ability to withstand shear, and additives designed for a particular end use are also important.
The shear aspect and the additive packages are why some of us donât think itâs the best idea to use the 20w-50 engine oil in a transmission. There are many reports of tranny damage where the 20w-50 was used. However, there are currently no scientific studies to prove the damage was the result of the use of those oils. You must make the decision as to your own bike.
Personally, Iâll continue to use gear oil in my tranny. There are enough differences in the engine vs. tranny applications that I feel better going that route."
Doesnât sound like an endorsement to use one in three, just verifying its possible.
I'll stick with gear lube in the gear box, Trick shift, or if I have to crank case oil in the primary, and good motor oil in the crank. Itâs to each his own of course. I will NOT be putting Shitgo in ANY vehicle I own. I am assuming HD oils are still being made by shitgo, any change in manufacture would be welcome news.
The oil opinions go on till the end of time. I just use harley products in all 3 holes. Will prob switch the SYN ,after engine gets broke in. Many say wait till 3 to 5K before SYN. More important is to change often. Oil is pretty cheap,A new engine is not cheap . very,very few oil opinions are based on fact : Just opinions.
