FUEL GAUGE HELP!!
Old Jan 28, 2008 | 02:03 PM
kjkustoms's Avatar
kjkustoms
Default FUEL GAUGE HELP!!
BREAKING DOWN THE BOB FOR NEW PAINT. GOT THE TANK OFF , CANNOT FIGURE OUT HOW TO GET THE FUEL GAUGE WIRES OUT OF THE CONNECTOR SO I CAN PULL THE GAUGE OUT OF THE TANK, LOOKS LIKE YOU FOLD BACK THE RETAINER ON THE PLUG TO EXPOSE THE WIRES AS THEY FIT INTO CONNECTOR, DONT WANT TO PULL TO HARD OR?? ANY ADVISE OR TIPS WOULD BE VERY HELPFULL, THANKS.
Old Jan 28, 2008 | 02:12 PM
mojo's Avatar
mojo
Default RE: FUEL GAUGE HELP!!
Ya you got the right idea but then you will need a safety pin or similar size tool to insert in the hole on the connector to release the metal tang that is hoding each wire, they won't pull out otherwise. I know Mud posted some really percise pics on how to do it if you do some searchin or if i find it I will come back and post it. The manual also shows the how to for this. Mojo
Old Jan 28, 2008 | 02:32 PM
mojo's Avatar
mojo
I couldn't find Muds pics yet but here is a link that i replied to quite some time ago with some pics that may help? You will see there are alot of folks that just cut them but the connector is really easy once you figure it out. Follow the link down to where i posted and you should see the pics.
Hope this helps, Mojo
https://www.hdforums.com/m_534068/tm.htm
Old Jan 28, 2008 | 04:03 PM
mud's Avatar
mud
ORIGINAL: mojo
kj, if it is an amp connector,
Have a look here.
this link should take you to page 11 of UNDER 50.
Look for posting # 403
https://www.hdforums.com/m_2546488/mpage_11/key_/tm.htm
mud
Old Jan 28, 2008 | 05:55 PM
kjkustoms's Avatar
kjkustoms
THANKS for the replies, tried the safety pin trick, it worked perfect!!!
Old Jan 28, 2008 | 06:26 PM
mojo's Avatar
mojo
KJ, glad the safety pin did the trick for you and glad to help. Be sure and posts pics after you get your paint job finished. Good luck, Mojo
stubby001
May 26, 2015 11:09 AM
maverick101
Jan 1, 2009 10:17 PM
wooosaa
Dec 30, 2008 09:18 PM
Shoe
Jun 8, 2008 11:36 AM
ace57
Feb 10, 2007 07:09 PM
