Ordered LSR's Today
Old Jan 30, 2008 | 02:09 PM
Beman's Avatar
Beman
Default RE: Ordered LSR's Today
It took 12 weeks to get mine. That sucked but after I got it i have been real happy with the results. Nice quality sound and the performance is good as anything out there.
Old Jan 30, 2008 | 02:57 PM
tshamba's Avatar
tshamba
I ordered the 1 ¾” slash cut B style with heat shields. I was tempted to order the 2”, but from what I read, the 1 ¾” will create better torque down low. I have the D&D FatCat on my bike now and the dyno curve is very steep. I am looking to create more usable power down low and I am willing to sacrifice some torque and power on the top to do so.
I’ve read all the horror stories about their customer service and lead time for the pipes. I can’t ride until April around here anyway, so I thought I would give it a go. I actually spoke to Bob on the phone for quite some time before ordering the pipes. He didn’t make any promises about performance. He was basically a no thrills guy and really believes that he builds the best pipes available for our machines.
Once I eventually get the pipes, I will post the dyno results.
Old Jan 30, 2008 | 04:05 PM
hmmr's Avatar
hmmr
sounds good, you mentioned you got large cams on yer ride, what ya runnin?
what all ya got on there anyhoo?
Old Jan 30, 2008 | 05:02 PM
mentor70's Avatar
mentor70
ORIGINAL: hmmr
Im curious too!
I just swithed to the Fat cat and I like the low end power curve that I have now.
If you cams are very heavy on overlap and duration no exhaust switch would help.
I had the Rinehart 2 to 1 on last week, its 1 7/8 primarys killed all my low end power.
I just came in from a 12 mile ride with the D&D and I had a lot more usable power on the low and mid range.
I think with a couple of small carb adjustments it will be a great pipe.
Old Jan 30, 2008 | 05:37 PM
tshamba's Avatar
tshamba
I am afraid you are correct mentor…I doubt the exhaust is going to make a huge difference, but I am hoping. I’ll swap out the cams if I have too.
Knight prowler 630 Cams
Ported and Polished
Wiseco Coated Pistons
Hell Fire rings
49mm Hillside Throttle body
Primo Clutch drive system
Injector work
Oddly enough the bike showed a nice dyno curve with the Vance and Hines Straight shots. It made better power with the D&D pipe but lost the low end. I am hoping the LSR pipe is a compromise and ends up somewhere in the middle.
Old Jan 30, 2008 | 05:46 PM
tshamba's Avatar
tshamba
I should mention that I did not build the motor. The work was all ready done when I bought it from a friend of a friend so I don’t have all the details. I am still waiting on the build sheet.
Old Jan 30, 2008 | 06:09 PM
2002fxdp's Avatar
2002fxdp
those pipes were my first choice but my wallet was more in favor of the Thunderheader
cant wait to see how it looks on you bike
Old Jan 30, 2008 | 06:39 PM
mentor70's Avatar
mentor70
ORIGINAL: tshamba
Ported and Polished
Hell Fire rings
Injector work
From what I can gather from Woods, the TW 9 cam is the only one with .630 lift. this is a stout cam, but Bob told me to get the best results with it I would have to change the primary gearing to 3.37 and then it would have "explosive" aceleration!
I think if It were me in this situation, I would leave the pipes alone and try to get the Woods T 6 cam or the Head-Quarters .575 cams, they both come on around 2200 to 2500 rpm and just slam you *** in the seat. They are some great all-around ridding cams that have gobbs of usable low and mid range power, and will pull to redline.
R&R has a .525 cam that is kinda new, but I heard its stump puller to. Andrews also has a #54 grind I think, but I have found nothing on the specs on there sight, so Ill call it "mystic" for now.
michael427
Nov 4, 2015 05:45 PM
13bob
Mar 30, 2015 04:16 AM
Roadie13
Mar 22, 2013 11:26 AM
SMOKEin
Apr 12, 2009 11:23 PM
rredneckn
Exhaust System Topics
Feb 7, 2008 07:41 AM
Slideshow: Harley-Davidson's new RMCR concept revives the caf racer formula with modern hardware-and it may be exactly the reset the company needs.
