Im trying to take the stock mufflers off of my Super Glide to put some SE's on . However them babies are on there something good. Anyone have a trick or tip for getting the originals off ?
Thanks
Well if you could care less about the mufflers you are pulling you can beat them off.
If you care about how they look for possible reinstall or whatever here are some things I done. Completely back off the tightening clamps and spread them apart so the end of pipe can expand. Then I have taken a angle chisle to spread the exhaust tube at the pipe cuts. Then you should be able to move the pipe up down side to side loosening it's fit and slideing off. Sometimes a rubber strap wrench works good to spin it while pulling and moving up down etc till off. Of course if you don't care about the mufflers beating them off is quicker .
I did all the the above, to get mine off except the beating off part............. May have felt better, but would have taken longer[sm=helpout.gif][sm=laughingsmilie.gif]
+1 On the Wd-40 and a Rubber Strap wrench. Works great if ya let the Wd-40 soak for a few minutes.
Good luck and Post some pics of them when finnished!
I had screaming eagles put on at the dealer. when i went to change out to vance and hines i had a hell of a time getting the s-e off. turned out each one was riveted on. now why'd they go a do that?
