Ideas for New Bars
Old Feb 11, 2008 | 09:08 AM
JayBee's Avatar
JayBee
Stage IV
Default Ideas for New Bars
Hi All,
Looking for some new bars for my 2007 FXDC, I'm sure that what I want is out there somewhere...But there are so many catalogues, hoping one of you can save me some time
I like the original bars...
The way they look
The angle of the grips
The height
But I need them a good two inches closer to me...Got a back problem & need to sit up straighter
Would be good to have somthing fatter, so I can put the wires inside.
I dont want to user risers, partly because of the look & partly because I'v got my tacho set up on the clamp and want to keep it there.
Any ideas of something that will do the job?
Many Thanks
John
Old Feb 11, 2008 | 09:17 AM
Chipstah's Avatar
Chipstah
Default RE: Ideas for New Bars
Take some measurements then check these sites out:
For stock harley bars, measurements by model:
http://www.sideroadcycles.com/Americ...tock_Bars.html
Or if there aren't any harley ones, check these guys out (Flanders):
http://www.sideroadcycles.com/Americ...andlebars.html
Old Feb 11, 2008 | 09:20 AM
2007fxdc's Avatar
2007fxdc
If you don't want to use risers, it sounds like you are pretty much limiting yourself to T-bars, which is what I went with. I have back problems as well (3 herniated lower discs and 3 uppers) but the stock bars didn't seem to be causing me a problem with that. I just didn't like the stock height with my 6'4" height and I didn't like the angle and the position my wrists were in. I needed something just a little taller with my hands more straight out to the sides. I went to the dealer and checked out different options to get just the right feel I was looking for. I liked the looks of the T-bars with 6" integrated risers but ended up with 8" risers for the perfect fit. There are lots of other options if you are willing to use separate risers. Maybe I am just confused about your comment about not wanting to use risers. Are you actually willing to use the basic risers and just don't want anything taller? Or do you not want risers at all? In any case, here are a few pics showing different angles of my bars. Also, there have been other similar posts to this in the past. So, you should be able to search and find posts that already include pix of different options.
[IMG]local://upfiles/41150/FEE1EF775401451BBC99BFB04A71AE0A.jpg[/IMG]
[IMG]local://upfiles/41150/C55598AAD17F44F6B76E03A66ADF74B3.jpg[/IMG]
[IMG]local://upfiles/41150/70B17111D23749F79B4809150945B974.jpg[/IMG]
[IMG]local://upfiles/41150/0AE3710EFD0848C18F60188FD631F73D.jpg[/IMG]
Old Feb 11, 2008 | 10:29 AM
bikerdog134's Avatar
bikerdog134
j. p. cycles has a small riser the sets the bars 2 inches back towards you but their not cheap about 175 bucks
Old Feb 11, 2008 | 11:39 AM
murphdog's Avatar
murphdog
I put Drag Specialties flat track bars on my FXDC along with some 4" high pullback risers. Overall, the grips arenearly 4" closer to me now. The bars alone come back about 2" further, but they're not as high as the stock bars. I know you said you don't want to change risers, but you'll get a couple inches further back with them. I have a Harley mini tach on mine with a 67207-04 Softail Standard mounting bracket to put it at the right angle with the pull back risers.
Drag 0601-0575
END RISE: 4 1/2”, WIDTH: 30 1/2”, CENTER WIDTH: 7 1/2”, PULLBACK: 11 1/4” - Flat track
$52.95
Something to keep in mind when trying to get a lot of pullback from bars alone...if you keep the same width, wrist angle is going to suffer.
Flanders has some "Super Glide" style bars that may be close to what you want. From Sideroadcycles.com
650-08235
D7: Super GlideÂŽ Type Bar, HD Dimpled Chrome, HD Knurled (4.5" o/s)
Diameter: 1"
Height: 6.5"
Pullback: 11.75"
Center: 7.5"
Width: 30.5"
Old Feb 11, 2008 | 06:40 PM
PsTaN's Avatar
PsTaN
Try ----> http://wild1inc.com/
Look at the 508's and the comparison they show with them on a RoadKing. May just be what you want.
Hope this helps ...
PsTaN
Old Feb 11, 2008 | 07:07 PM
itileman's Avatar
itileman
Have you thought about Beach Bars. May go that route with my Low Rider this summer. Missed a great set for cheap on eBay last month.
Old Feb 11, 2008 | 07:41 PM
okietazman's Avatar
okietazman
JayBee:
I just put "Chubby Wild 1's Low Profile" bars on my Low Rider for the same reasons as yours (need about 2" more pullback, risers and bar are one solid piece, wiring goes inside bars). Finished Saturday afternoon and the test ride was great, more control on turns, just better feedback from the bike all around. I will try to get some pics when the weather clears. Check them out, think ya might like them. Here's the site:
www.wild1inc.com and they have some pics of their bars on several different Harleys.
JayOhh
Aug 14, 2014 11:48 AM
ryan9977
Jun 8, 2013 08:16 AM
diddydido
May 28, 2010 07:59 PM
SgtThump
Apr 22, 2008 07:23 AM
PoorBoy
Dec 17, 2007 05:43 PM
