fuel crossover
Thanks in advance.
Glen Gibson
07 Bob
If you do change it out, I can't remember who it was, but I just got done taking my tank off putting back on for handlebar swapout, and another member suggested I try the following, which worked with very minimal drippage/spillage:
you'll need a long funnel, as the crossover line isn't very long, so not much to feed into the funnel
before doing this below, try to siphon as much gas out of the tank as possible, then proceed with the following-
1.take 2 small vice grips and clamp the fuel line shut on both sides, with enough room to cut the line in the middle
2.cut the line in the middle, put a 5/16" bolt in each side to reduce risk of any leaks past the vice grips, and one side at a time release the vice grips and drain into a gas can. don't know why, but it seemed that there was more fuel remaining on the left side of the tank, so maybe try draining left side first, as it took alittle longer
sorry this isn't more thorough, but I think you get the idea, its early, and have to be off to work soon. good luck, it isn't that difficult, a dummy like me was able to do it with no problem, just time consuming letting all the fuel drain out. make sure you do it outside with plenty of ventilation, and keep open flames away of course.
one more thing, it might help to remove the aft tank mounting bolt, 1/2 in nut/bolt, and loosen the forward so you can lift the aft part of the tank up a bit to ease in the draining process, and I can't help but think that removing the gas cap will aid in the flow out through the tubes as well.
just found it - Here's the link from advice given for my tank drain:
https://www.hdforums.com/m_2872277/tm.htm
The instructions tell you to 'bottom out' the nut when you tighten it against the rubber bushing but the problem seems to be in that the fuel line is very stiff and puts a lot of side tension on the bushing which in my case cause the bushing to be pushed out of the back side cap nut on both sides.
Took it back to HD and replaced it with a kit from JP Cycles that had braided line and 6 connectors that worked perfectly.
Oh yeah, forgot to add that when I changed mine initially, I ran the bike down till the low fuel light came on and then just jacked up the front of the bike causing the rest of the fuel to pool to the back side of the tank. Replaced the line with no fuel loss.
When draining the tank and cutting the crossover line and replacing it what type of hose clamps do you use? I have used the screw on worm type and also the original snap on type after borrowing the correct tool. Any one have any preferences or better suggestions?
