I scored a new primary cover
Old Feb 19, 2008 | 10:43 PM
JayFromPa's Avatar
JayFromPa
Default RE: I scored a new primary cover
I'm not saying it won't work, you'll just need to make sure the hole is sealed good on that inner. For example, I went from a stock silver inner on my FXD to a black inner from a SE Dyna, hence no factory hole on the outside part of my inner to worry about. But, because I'm running a Street Bob outer with the plug in it (which I just painted black to match) theoretically I could possibly have the same issue, just not as likely to since the outer primary is at a downward tilt the majority of the time and a lot easier to get to if I saw any sign of it leaking. It's just food for thought before you get into it.
Old Feb 19, 2008 | 10:48 PM
SURFOR Chop's Avatar
SURFOR Chop
Bra ... I'll take it off your hands! That or you could just get one of these kits from V-Twin Mfg.
R/
Priest
[IMG]local://upfiles/29151/5E3D80A74E29486C8CFD223EDC4CA2C2.jpg[/IMG]
Old Feb 19, 2008 | 10:54 PM
TOMMAY's Avatar
TOMMAY
Hell,there's thousands of Street Bobs running around with forward controls and a plugged hole in the inner primary.Not a big deal. Not to worry.
Good Luck
Tom
Old Feb 20, 2008 | 06:39 AM
JayFromPa's Avatar
JayFromPa
That's what I was trying to say in my last post. I realized that I may have freaked him out a little bit, and gave him the impression it was a bad idea. I just wanted to make sure he realized this before he started tearing into it. Some guys might not like the idea of that hole being there. Better he knows now than later.
Old Feb 20, 2008 | 04:36 PM
williamfrog's Avatar
williamfrog
Someone on here said to use a freeze plug but I can't remember the size ?
Frog
Old Feb 20, 2008 | 09:39 PM
HogGlider's Avatar
HogGlider
Hey nice job man! I picked up my cover (same, no hole for mids) from my dealer's ebay store for $7.00, about time I get an upper hand lol.
Just picked up my inner cover last week and am just going to get a length of properly threaded rod, cut to size, add JB weld to the threads and screw it in. No leak issue and the hole will stay plugged!
Old Feb 20, 2008 | 10:04 PM
fastfxrs's Avatar
fastfxrs
Had the same deal on my FXRS with forward controls. The guy before me had an aluminum plug welded in the inner primary. It worked for a lot of miles before springing a significant leak from a pinhole in the weld. I cleaned it good and JB welded over the whole thing. It never leaked again.
Tim
Old Feb 20, 2008 | 10:46 PM
Trotter's Avatar
Trotter
9mm freez plug works perfict..... .50 cents
ORIGINAL: JayFromPa
ruffjeepster
Dec 30, 2016 02:08 AM
coop creek
Mar 30, 2012 09:01 PM
Roadrider18
Jan 10, 2007 04:54 PM
helotaxi
May 28, 2005 03:27 PM
airems
May 16, 2005 01:35 PM
