'08 riser torque check
Old Feb 23, 2008 | 07:10 PM
Lone Watie's Avatar
Lone Watie
Default '08 riser torque check
Can someone please verify the torque on the '08 dyna fxdf/fxdwg riser bolt coming up from the bottom? If I read the service manual correctly, it is 30-40 ft. lbs., and I just want to be sure. Thanks in advance.
Old Feb 23, 2008 | 07:37 PM
Muddyape's Avatar
Muddyape
Default RE: '08 riser torque check
yep
Old Feb 23, 2008 | 07:54 PM
Lone Watie's Avatar
Lone Watie
reason asking is that I installed the polyurethane bushings, and the instructions for those state the torque is 144-180 in. lbs, which is 12-15 ft. lbs, which is a quite a bit less than 30-40 ft. lbs. I guess poly bushings don't need to be torqued down as much, or what?
apetterez
Nov 12, 2014 03:37 PM
purdie
Mar 21, 2012 11:17 PM
ScReaMnEagLE22
Nov 9, 2009 07:07 PM
WillieD
Dec 24, 2008 10:15 AM
singlepin
Mar 14, 2008 11:00 AM
