Fork Oil
Old Feb 24, 2008 | 05:28 PM
Dizzzy's Avatar
Dizzzy
Default Fork Oil
Ok...dip **** question. I'm assembling my forks after having them powder coated.....all done. Now I need to fill them up with oil. Do I just need to dump the perscribed amount of oil down the tubes then TRY to get the top tube bolt threaded?...or am I missing something?...and is there a trick to getting thetop tube bolts in since Ineed to compres the springs? Thanks
Old Feb 24, 2008 | 08:12 PM
Dizzzy's Avatar
Dizzzy
Default RE: Fork Oil
Nothing?
Old Feb 24, 2008 | 08:45 PM
cou9ar's Avatar
cou9ar
I think you should have a drain/fill plug on the bottom (where it curves around the axle) and there after the springs are compressed you put in the prediscribed amount of oil................I would think
Old Feb 24, 2008 | 08:54 PM
Sec Super Glide's Avatar
Sec Super Glide
Have a buddy help I had a neighbor stop down.
Baeseman1's Avatar
Baeseman1
ORIGINAL: Dizzzy
When I changed my fork oil, I released the pressure on the front forks. A bike jack or 2 I-bolts in the ceiling with ratchet straps... That should release the pressure enough for ya. Then I dumped in the prescribed amount of fork oil. I went with Bel-Ray 15w fork oil found at my local metric store.
Old Feb 24, 2008 | 10:13 PM
mud's Avatar
mud
ORIGINAL: Dizzzy
Diz - what year model is your machine???
On the 06 up, there is not a prescribed amount.
There is a measurement down
from the top of the fork pipe
to the top of the oil.
The measurement is taken
After
pumping the air out of the oil
that you have just put in.
mud
Old Feb 25, 2008 | 07:37 AM
Dizzzy's Avatar
Dizzzy
It an 07 SG....So..I put the amount of oil in that they perscide them pump the forks up and down after I take it off the lift...then take the caps off again and measure after I put it back on the lift??...and I fill it from the top?
Thanks guys
Old Feb 25, 2008 | 09:02 AM
mud's Avatar
mud
ORIGINAL: Dizzzy
Thanks guys
Diz, here's a little info -
Old Feb 25, 2008 | 07:01 PM
Dizzzy's Avatar
Dizzzy
Thanks guys!
Mike Kirk
Nov 26, 2016 01:49 AM
Eric The Welder
Oct 16, 2011 03:37 PM
kjkustoms
Jan 23, 2009 06:30 AM
ajl10spro
May 7, 2008 11:16 AM
earthdog
Sep 21, 2007 02:44 PM
