Anyone know why I couldnt run these risers on my 08 SG. I am looking to relocate the speedo with a T-Bargauge mount. Would like these risers with Drag bar. Personally couldnt see why this set up wouldnt work, but wanted to make sure before the purchase. I know the Night train set up has been used, was just looking for a different riser type. Thanks for your help. Pictures please if anyone is running something similiar.
does it say what the diameter of the riser is? you need to know this, don't assume it's 1" or 1.25". ASK!
do you plan on mounting the speedo to the fron? that would work. you probably will not be able to "reverse mount" the speedo over the tank, the rise is not enough and the speedo will hit the tank.
They are 1" and I am using a 1" drag bar whichI am mounting the speedo to the front of. I have seen a similiar riser set up on wg's (minus the mounted speedo). I just wanted to make sure I wouldnt run into a problem. Thanks for the response!
