Hard shift?
Old Mar 1, 2008 | 12:53 AM
prlswabbie's Avatar
prlswabbie
Default Hard shift?
Has anyone else had problems your bike "hard shifting"? Whenever I gear down, sometimes there's a loud CLUNK! (07 SB)
suggestions, input?
thanks guys
Old Mar 1, 2008 | 01:09 AM
carnes99's Avatar
carnes99
Default RE: Hard shift?
It is normally pretty loud but if you feel that it is louder than normal take it to your local dealer and i'm sure they would give it a quick look.
Old Mar 1, 2008 | 02:39 AM
Gunshow's Avatar
Gunshow
ORIGINAL: prlswabbie
suggestions, input?
thanks guys
That only happens for me going form first to second. But I like it. When I hear the thunk I know I'm in first. I think you should onlybe concerned if you notice it causeing operational issues or safety issues.
Old Mar 1, 2008 | 06:56 AM
pappy43's Avatar
pappy43
If you think something is bad wrong take it to your dealer if you want thepeace of mind, but, I guarante all your going to get is "thats normal" ! I don't think I've every owned any make (and I've had a few) bike that didn't Clunk going to first.
Old Mar 1, 2008 | 08:34 AM
dyna07custom's Avatar
dyna07custom
ORIGINAL: pappy43
+1
Old Mar 1, 2008 | 09:13 AM
103M's Avatar
103M
It's the nature of the beast! You gotta figure they've beefed up the tranny's quite a bit in the last couple of years. But, make yourself feel better and talk to your dealer.
Old Mar 1, 2008 | 01:27 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Go get yourself some Redline Shockproof Heavy gear oil from Summit Racing or myoilshop.com and it will quiet that trans down a lot. Check it out at www.redlineoil.com
Old Mar 4, 2008 | 08:15 PM
johnfxdb's Avatar
johnfxdb
To be honest...after owner several Harley's, i would be more concerned if it DID NOT make noise when shifting.
Old Mar 4, 2008 | 08:50 PM
Bobber S's Avatar
Bobber S
If you want to reduce the "clunk" try slowing down more before down shifting .. anyway "clunk" is considered normal but should not be "hard to "downshift" this could be a problem, first check your trans fluid. I had a bike once that became hard to downship on very hot days.
Old Mar 5, 2008 | 04:47 PM
Pixs's Avatar
Pixs
Hi prlswabbie,
Before you go off the deep end, try changing your transmission oil to Mobile 1, 75W 90 gear oil (synthetic) and your primary fluid to Type "F" ATF.
Good luck and have a good day.
Best,
Pixs.
47909Rider
Jun 28, 2013 08:35 AM
harlot
Apr 24, 2011 10:07 PM
SgtThump
Nov 20, 2007 07:12 AM
Sreynold1
Jul 5, 2006 10:21 PM
roadster rider
Oct 11, 2005 05:03 PM
