oil change questions
Old Mar 2, 2008 | 02:56 PM
06dynablack's Avatar
06dynablack
Default RE: oil change questions
5/8 standard socket with extension works great to pull oil plug.nother pic for oil plug
[IMG]local://upfiles/9202/C92CB29AA1434897B195AD62970D1EBF.jpg[/IMG]
Old Mar 2, 2008 | 03:31 PM
pwer pla's Avatar
pwer pla
Sounds like you pulled the tranny plug to me, pull the trans dipstick and check. Also fyi when I refilled the oil on my wg the capacity says 3 quarts but it will only take about 2.5 b/c there is about 1/2 quart that doesn't drain. Didn't read the directions close enough when I did mine the first time and ended up dumping about 1/2 quart of oil all over garage floor. Not sure if the bob is the same but I would guess that it is. Good luck
Old Mar 2, 2008 | 04:29 PM
harper764's Avatar
harper764
yea, i figured it out. thanks though for all the replies.
Old Jun 3, 2008 | 12:05 PM
2WHEELSTILLIMGONE's Avatar
2WHEELSTILLIMGONE
Stage III
[align=center]YEP, YOU HAVE DRAINED THE TRANSMISSION
BUY A QUART OF 75 90 TRANS FLUID FILL SLOWLY AS TO NOW OT OVER FILL
THE OIL PLUG IS A ALLEN WRENCH PLUG ON THE FRONT.
DEALERS WILL TELL YOU IT HOLDS 3 QTS...
BUY 3 TO HAVE ON HAND... BUT FILL SLOWLY. MOST DONT HOLD 3 AND YOU DONT WANT TO HAVE TO PUMP IT BACK OUT.
CONTACT ME IF YOU NEED MORE HELP..
[/align][align=center] [/align]
Old Jun 3, 2008 | 12:15 PM
Cornhusker's Avatar
Cornhusker
I'm bettin he's got it fixed by now. That thread is 3 months old.
Old Jun 3, 2008 | 12:48 PM
maddghost's Avatar
maddghost
I don't have a pic,but I did the exact same as you yesterday! pulled the wrong plug and out came the primary oil! the engine oildrain plug,if you look from the same side as you removed the primary by accident is just a little further under the bike about 6 inches and faces out towards you. it is the same 5/8 inch plug,just sideways. You will have to get hd formula + oil for that which is the same as the tranny fluid,unless you are going for higher tek fluids,that's up to you. And according to my manual it takes .95 liters,or 32 ozs. the engine needs 2.4 litres or 2.5 quarts. I'm giving ya both standards since i'm not sure where your at!
Old Jun 3, 2008 | 12:50 PM
maddghost's Avatar
maddghost
ORIGINAL: 07 StreetBob
HE HE HEEEE! my goof up was last night!
Eborjas
Oil Archive (no new posts)
Apr 23, 2019 05:54 PM
sprocketbos1
Dec 22, 2010 07:34 PM
ELAMARZ
Sep 12, 2006 10:58 PM
bigdog75x
Mar 30, 2006 02:22 AM
phreak
Mar 14, 2006 09:51 PM
