rear tire clearance
Old Mar 10, 2008 | 07:59 PM
SM49's Avatar
SM49
Default rear tire clearance
I'm having clearance problems when I put on 11" progressives,the rear tire rubs the fender on the left side.
Old Mar 10, 2008 | 08:58 PM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: rear tire clearance
That's wierd I've got the 11" Progressive HDs and my tire doesn't rub at all. Are you sure it's the tire?It's possible for the fender to hit or rub the belt guard when you go to lower shocks.Try cranking up the shocks a couple notches.
Old Mar 10, 2008 | 09:03 PM
flatblk's Avatar
flatblk
I also have the 11" progressives with no issues.
[IMG]local://upfiles/50617/286C251E798B41FC8C6779D5C45BC1E4.jpg[/IMG]
Old Mar 10, 2008 | 09:35 PM
SM49's Avatar
SM49
I thnk it is more of a centering issue
Old Mar 10, 2008 | 09:36 PM
SM49's Avatar
SM49
The tire doesn't seem to be centered in the fender.
Old Mar 11, 2008 | 06:27 AM
SkyRider's Avatar
SkyRider
you put a spacer on the wrong side?
Old Mar 11, 2008 | 06:47 AM
rickshog's Avatar
rickshog
sure sounds like it... but the spacer from the passengers side wouldnt even stick out enough to keep the pulley from smackin right into the swingarm no??
Old Mar 11, 2008 | 07:21 AM
SM49's Avatar
SM49
I wondered about that, I just bought the bike in January,looks like the spacers can't be mixed up easily,wide one on left side.
Old Mar 11, 2008 | 07:24 AM
jmpancoast's Avatar
jmpancoast
ORIGINAL: SM49
Are you sure the wheel is properly aligned?
Old Mar 11, 2008 | 12:01 PM
SM49's Avatar
SM49
it is aligned by the holes in the swing arm.
junglejoe
May 7, 2013 08:50 PM
va_rider
Sep 13, 2010 09:50 AM
SkyRider
Jun 10, 2008 01:49 PM
dslocum
May 28, 2008 07:17 AM
SM49
Mar 24, 2008 06:34 PM
