brake light
Old Mar 20, 2008 | 12:11 PM
daddiokool's Avatar
daddiokool
Default brake light
a quick question ... my rear brake light does not come on when applying rear brake. Light comes on when front brake is pressed. Running light works also! Is this a simple bulb replacement or should I look for something wrong with the rear brake cable ?
thanks for the input fellas
Old Mar 20, 2008 | 12:21 PM
The Baron's Avatar
The Baron
Default RE: brake light
If the brake switch goes bad the brake light will normally stay on. If it works fine using the front brake I would suspect a wiring problem with the rear brake switch. You may have a pinched wire or smoked fuse. I would chase the wires fromt he rear switch and look for issues there.
Old Mar 20, 2008 | 12:22 PM
TacomaSG's Avatar
TacomaSG
Hi Daddio, did you recently change out your grips? If so you may have broken your brake light switch.
Old Mar 20, 2008 | 12:24 PM
Critter174's Avatar
Critter174
bulb is ok if it works when you hit the front brakes. the rear look down near you master cylinder there is a wire there check and make sure nothing is wrong with it and that it hasn't come off. if it's not that then next would be the pressure switch for the rear brake.
Old Mar 20, 2008 | 12:49 PM
The Baron's Avatar
The Baron
If either switch goes bad the brake light will stay on all the time. So considering the fact that the front works fine you can skip that. This moves us to the rear switch. Obviously the switch isn't bad or the brake light would always be on. This means that either the wiring has come off the switch or the wiring is damaged in some way.
Old Mar 20, 2008 | 12:59 PM
wkdavistx's Avatar
wkdavistx
ORIGINAL: The Baron
or the switch for the rear brake is stuck in the "in" position failing to turn the brake light on when the rear brake is applied. Does this seam like the obvious problem or am I retarded?
Old Mar 20, 2008 | 02:01 PM
daddiokool's Avatar
daddiokool
thanks for all your advice !
Old Mar 20, 2008 | 02:04 PM
The Baron's Avatar
The Baron
ORIGINAL: wkdavistx
I've never seen a pressure switch get stuck in that position, but hell, anything's possible. Perhaps I'm overthinking the situation. I would probably slap a new switch on if the wiring wasn't obviously disconnected or damaged near the switch.
Old Mar 21, 2008 | 12:11 AM
wkdavistx's Avatar
wkdavistx
It could be gunked up from road grime.
uride2
Electrical/Lighting/Alarm
Apr 4, 2017 05:47 PM
eddy287
Jul 18, 2013 10:07 PM
Deelux
Jul 30, 2012 08:40 PM
RoadKingHellas
Jul 28, 2012 04:09 PM
1986FXST
May 31, 2008 05:35 PM
