o2 sensers 2006 dyna
I'm definitely going to try it though. I've done quite a bit of EFI tuning on drag cars with both gas and alcohol so it shouldn't be too bad. The only thing different is with the cars I have to build everything from scratch with a laptop where I believe these give you preset options.
I really don't know that much about the different programmers so do a lot of research before going to get one and I'd say to look for something you feel comfortable with doing yourself.
There is no warm and fuzzy from that...
BTW: This forum rocks!! Thank goodness I found it because who know how much time and money I would have wasted based on the bad advice I had gotten thus far.
due to the faster escape of the exhaust the o2's will basically give a false reading which will change the ecm's capability to correct the the already lean condition because of back pressure and temperature of the exhaust.
My EFI knowledge comes primarily from cars so I am learning as well. It seems a bit ridiculous that when operating closed loop, the adjustment range is so narrow although it certainly could be. Another possibility is that the closed loop function IS adjusting adequately, but from what I've read at WOT you are operating open loop so that data comes exclusively from a table.
I don't know that any of the closed loop offsets or adjustments are applied to this table. If not, then the real problem could be the open loop operation at wide open throttle. Closed loop operation could be a problem as well, I don't know that it isn't, but I am pretty confident your system's self-adjustments won't help at WOT.
That could be part of the reason some folks find they need to reprogram and others don't for a stage 1??? Car EFI systems operate open loop at warm up as well as WOT because the sensors are not accurate until a certain temperature range and of course the engine runs dramatically different as well when it's cold. But if you take long, gentle rides with very little wide open moments, you operate mostly closed loop and that is at least adjusted somewhat. If you take short rides and do a lot of blasts of WOT, then you operate more in the open loop mode.
At least when warming up, it should be plenty rich. So perhaps the closed loop mode is truly not very adjustable or perhaps WOT is the bigger issue. I'm not sure it matters much because I think either way, you need to get the EFI reprogrammed with any changes. I haven't decided on my personal solution yet either, but I am leaning towards SERT. That is the *correct* way to handle the problem, it just isn't as easy as some of the others claim their solutions are.
Kevin
Kevin
Does anyone know any good books or manuals dealing with the theory of operation of these devices. If I am going to do it I want to understand everything that is going on and not just be tied to numbers fed to me by a second party.
Jeff
You can look in this forum for some help on the various units.. https://www.hdforums.com/forumid_247/tt.htm
hey kpreese me to ithink one thing that i faild to take into cosideration is that most efi sys. today is that they have mss air flow sen. that helps to adj. for high flow intakes & exhaust the hd sys is more like a tbi witch has much less capabilaty to do so
In my previous post I was just saying that the EFI system *should* be able to adjust to handle this in closed loop mode. I don't *know* that it does. My point was that regardless of how well it adjusts in closed loop mode, you will probably still not be getting enough fuel in there at WOT.
These add-on boxes that intercept the signals and tweak them . . . in closed loop mode, the bike will be doing the same thing it always does, targeting a borderline lean condition. So you richen it up and in closed loop mode, it will simply lean it back out. Depending on how much the EFI system can adjust, it will offset the benefits of one of these add-on boxes (in closed loop mode). Even if the bike can't adjust all of the added fuel back out, it still will change the performance after you tune it. So if you tune it, it will go out of tune. That problem is well known in the performance car arena. Because of the inherent problems with these boxes, I haven't followed their "progress". Perhaps these new boxes have some new tricks up their sleeves, but I don't think so. I think the same old problem still exists.
Despite that, I would think an add-on box would be effective at WOT because the system isn't relying on feedback to hit a target. So whatever tweaks you put in place should stay in place.
Anyway, my point was just that you pretty much need to get a reprogram or add some device if you make changes because of open loop function whether closed loop mode adjusts properly or not. But I suspect the SERT is probably the only way to effectively help with both closed loop and open loop function.
Kevin
