Paint or Powder?
Old Mar 22, 2008 | 07:32 PM
Dyna Don's Avatar
Dyna Don
Default Paint or Powder?
Ok so I painted my stock heat shield today (Thanks for the info baxter) to see if I like it and I do so I want to do my V&H big shots but I am unsure on the duability of the paint so my question is;
How well does the paint hold up?
and
Has any one ever used this http://www.eastwoodco.com/jump.jsp?i...amp;itemID=458?
[IMG]local://upfiles/54949/A2C991CE8FA94B2A910B1A5F9E4F62F2.jpg[/IMG]
Old Mar 23, 2008 | 11:13 AM
hk_shooter's Avatar
hk_shooter
Default RE: Paint or Powder?
The guy who does my powder uses all Eastwood stuff. I'm pretty sure he's happy with the results, he's been using it for a while.
Old Mar 23, 2008 | 07:29 PM
Dyna Don's Avatar
Dyna Don
Thanks HK, I think I 'm going to try it. I picked up an oven today for $25 and I am going to do some welding to it to make it big enough and see how it goes.
Old Mar 23, 2008 | 08:08 PM
Bluetoys's Avatar
Bluetoys
might sound dumb to suggest, but it has to be electric and not a gas stove. I am not saying anything about you, nothing was said about the type you bought. Just mentioning it in case it was a gas stove or (mostly) for the next guy reading this that wouldn't think of it.
Old Mar 24, 2008 | 10:45 AM
hk_shooter's Avatar
hk_shooter
ORIGINAL: Bluetoys
Most excellent point, Bluetoys!!
And Dyna Don, as for good results, it's all in the prep work. If you take your time and prep it well, you'll be happy.
I'm guessing you bought an old 'garage sale' oven?
Old Mar 24, 2008 | 12:08 PM
Stanger's Avatar
Stanger
Powder coat is what I did and would do again. I have known a guy who used the Eastwood company system for car parts and it looks no different then my stuff professionally done. Good luck!!!
Old Mar 25, 2008 | 05:51 PM
Dyna Don's Avatar
Dyna Don
Actually I bought three of them one from a yard sale and 2 came from Lowe's damaged I want to build one big enough to do a frame so i am going to put three burnersin it. Not sure how I am going to wire it but I will figure it out.
Old Mar 25, 2008 | 06:18 PM
hk_shooter's Avatar
hk_shooter
My coater started off with an old ice cooler, like they have at mini-marts and gas stations,and 3 ovens(IIRC) and mounted the heating elements inside. It was already insulated and with only minor mods(opening one end to allow big stuff to be inserted and adding a rail to hang the parts from), andit was ready to go.
He can do bike frames, car/truck bumpers, brush guards, etc. and other larger items.
The trick is keeping a constant temp. The parts, not just the interior of the oven,must 'bake' at a certain temp(about 450, IIRC) for a certain length of time.
I believe he uses one of the handheld pyrometer(?) guns with the laser pointer to check the parts temp.
Notallowing all the hot air to rise, he uses a small fan to circulate the air.
Not sure about the wiring diagram, I think he found an old electrical control panel, like in machine shops, and has seperate controls for each element.
I can pick his brain and possibly get some pics, if you need.
Hope this helps...
Old Mar 25, 2008 | 07:34 PM
Dyna Don's Avatar
Dyna Don
Yeah this is what i am trying to do with a circulation fan in the back.
[IMG]local://upfiles/54949/5BB77E62ECFE45739BD121F99F268004.jpg[/IMG]
Old Mar 25, 2008 | 07:36 PM
Dyna Don's Avatar
Dyna Don
BTW thanks for the info much appreciated
Softailman04
Jul 29, 2022 09:44 AM
cando
Nov 16, 2019 03:21 PM
apetterez
Oct 28, 2014 06:10 PM
Rabbito
EVO
Aug 27, 2014 08:37 PM
CheGuevara
May 13, 2010 07:22 AM
