SOME SHOCK SWAPPING ADVISE?
Old Mar 27, 2008 | 03:15 PM
HATZO1's Avatar
HATZO1
Default RE: SOME SHOCK SWAPPING ADVISE?
I just changed my shocks out and did it the same way the trampsinger did his and it was all fine. I had a friend there to spot , just as I like to play things safe. But my spotter did nothing other than watch. Maybe its not the proper way via the book but it works fine and is quick.
Old Mar 28, 2008 | 10:09 AM
07bobber's Avatar
07bobber
well i had my little brother help me and im about halfway done. this was an expensive inch. hopefully shell look good and ride good.
Old Mar 28, 2008 | 12:00 PM
Droop's Avatar
Droop
I made the mistake of replacing new progressives one at a time. The new oneswere an inch shorter than the the old ones. Wound up stripping a a bottom bolt. Take 'em both off first if there's a difference in size.
Old Mar 29, 2008 | 11:03 AM
Belly Dragger's Avatar
Belly Dragger
I put my 11" progressives on by my self on the kickstand in a few minutes no problems
Old Mar 29, 2008 | 11:18 AM
007dyna's Avatar
007dyna
Yes both at the same time. I put mine on a jack stand. Once you've got either the top or the bottom bolts in, lower the jack a bit and USE GRAVITY to raise your swingarm so that the other bolts go in. Takes about 15 minutes.
Delta
May 20, 2020 05:53 AM
KrakkyDoo
Air Suspensions
Apr 27, 2012 06:29 PM
KeeBee
Mar 5, 2011 08:44 AM
jp1212pc
May 30, 2008 07:22 PM
tcsblues
May 5, 2007 05:55 PM
