pc lll ? please help
Old Apr 4, 2008 | 08:55 PM
mn roamer's Avatar
mn roamer
Default pc lll ? please help
ok guys have a 07 street bob put on pc ontonight but the tank and fenders are geting work on my ? is when i turn the key to the first spot when the headlights come onthe pc lll does not light up at all is this right or do i have something wrong
Old Apr 4, 2008 | 09:13 PM
wkdavistx's Avatar
wkdavistx
Default RE: pc lll ? please help
When you turn the switch to 'Ignition' the PCIII should light up.
Old Apr 4, 2008 | 09:14 PM
07denimbobber's Avatar
07denimbobber
the power commander works off of the fuel pump so the bike has to be running....
Old Apr 4, 2008 | 09:18 PM
mn roamer's Avatar
mn roamer
thanks guys i should be getting the tank and fenders back from paint i cant wait ill post pic when i get it all together
Old Apr 7, 2008 | 01:26 AM
wkdavistx's Avatar
wkdavistx
The bike can't run without the fuel pump. The fuel pump runs off the ignition switch, so when the ignition switch is in the right position the fuel pump pressurizes and the PCIII comes on. ????
Old Apr 7, 2008 | 09:29 AM
joe.1955's Avatar
joe.1955
ORIGINAL: wkdavistx
Correct. But if the bike isn't started before the fuel pump shuts off, the PClll will lose power again until the starter is energized - then it has to power up causing a delay in starting. That's why you start the bike before the fuel pump shuts off - no delay.
snkebyt
Mar 5, 2010 09:48 PM
maineultraclassic
May 10, 2008 08:47 AM
luckystars5
May 2, 2008 08:32 PM
jpowell490
Feb 27, 2008 02:14 PM
RWM
Members Meeting Members
Mar 27, 2007 05:03 PM
