Power Commander Install - No start
Bike started up fine, idled fan, gave it some throttle fine, hit the throttle a second time and it quit. Now it won't start.
Wanted some thoughts on the situation, so I can get on the case later today. Thanks.
Did you disconnect it and try to start it again?
When you try to start it, does the starter activate or is it completely dead? If dead, check your handlebar on-off switch. Don't laugh, as this has been the oversight once or twice in the past.
If it cranks but no start, have you tried starting it without the PCIII installed?
Maybe the map is just way off? I need one that matches my setup-Stage1, Fishtail Slip-On Drags. Dynojet suggested the Stage1, Khrome WERKS +100 Slip-Ons. All I know is that it's definately not running correctly.
1. Connect the 9V adapter to the PCIII and the USB to the PCIII and computer.
2. Start the PC software and go to Power Commander Tools > Set Throttle Position.
3. Switch on the ignition but don't start the bike. In the small window click on Reset, wait a few seconds for 0% to settle, then turn the throttle to 100% (WOT). When the large number in the window settles (a second or two) and click OK.
4. Go to the main window and check that both 0% (idle) and 100% (WOT) are showing correctly with the corresponding throttle inputs. If WOT shows 98-99% don't worry about it, as that's close enough.
TP on non-TBW bikes are usually off quite a bit out of the box (mine showed 6% at idle), so it is important to set it sooner rather than later. FWIW, the procedure for the PCV is the same except there's no 9V adapter. TBW bikes should not use the Reset button, but you should instead manually insert these numbers into the "closed" and "open" boxes:
08-09 Touring:
Closed throttle 0.700 (Minimum Voltage)
Open throttle 4.300 (Maximum Voltage)
I don't have the values for 2010 models.
