Tail light ?
Old Apr 8, 2008 | 03:52 PM
2007fxdc's Avatar
2007fxdc
Default RE: Tail light ?
ORIGINAL: JRK5892
cool brother... let me know if you need a hand with the wiring... i am sure you can make it work!
The wiring will be no issue at all. I'm sending him the harness that plugs the light directly into where the stock bulb socket harness plugs into. Assuming the LED module fits into his existing lense, all he'll need to do is put something in there to hold it in place within the lense and he's good to go. If the LED module doesn't fit the lense for some reason, Joe, it looks like you'd be in business.
Old Apr 8, 2008 | 06:09 PM
mikeurig's Avatar
mikeurig
Replacing a regular bulb with an LED one is useless, not enough light gets emitted sideways.
You don't need an equalizer if you just change the brake light.
I've been there done that. I went back to the stock tailight.
Word of wisdom, when I bought a laydown tailight the company sent me an led bulb cause the bulb was too close to the lens and could melt it.
http://www.customdynamics.com/motorc...z_LED_Clusters
Old Apr 9, 2008 | 08:05 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: mikeurig
Mike, I hooked him up witha full LED panel out of my cracked Kury tail light. As long as it fits, he should have no issues. It's very bright with a lot of LED bulbs in it (see pix above). I agree that the LED substitution bulbs that are made to fit into the sockets used for stock bulbs probably aren't strong enough to be safe. I've also heard of regular bulbs melting the laydown lenses and wouldn't suggest trying that.
Old Apr 11, 2008 | 12:32 AM
BluBob's Avatar
BluBob
Mikeurig,
Nice picture! I am looking into removable side plates (and the back rest, pad, ect.) and it looks like you have a set mounted. Were you able to do it without re-locating the tail lights? Thanks.
Stephen
Old Apr 11, 2008 | 04:29 AM
mikeurig's Avatar
mikeurig
My sideplates are nonremoveable and I didn't have to move the lights.
Old Apr 11, 2008 | 08:50 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: BluBob
Mikeurig,
Stephen
Blu, you don't have to physically relocate the lights (I assume you meant signal lights?) with a detachable sissy bar. With the hardware, you have to buy what they call a relocation kit but it doesn't actually move the location of the signals. As part of the install, you remove the signal lights, including cutting the wires, and change out the "stalk" but they go back on with the detachable hardware in the same place they were. I have the setup on my bike although I don't often mount my sissy bar so you can't really see it.
Old Apr 11, 2008 | 08:28 PM
BluBob's Avatar
BluBob
Mike,
Thanks for the info, I am set to go for it. I installed a shorter set of stalks on the signals a few months ago, so I am in on the secret of how to unplug the small connectors on the leads. I guess the short mounts will still work with the lights and the docking hardware. I just havent been able to get a straight answer from the stealer on how it all goes together.
Stephen
Old Apr 11, 2008 | 09:06 PM
jjwin98's Avatar
jjwin98
What kind of equalizer would I need to put some LED turn signals on a 06 street bob
for just for run, turn any info would be great
thanks
Old Apr 11, 2008 | 10:39 PM
BluBob's Avatar
BluBob
I looked into some from Drag Specialties,
http://www.dragspecialties.com/fatbook/17/178/5921140
http://www.dragspecialties.com/fatbook/17/178/5921209
[IMG]local://upfiles/58191/EF927F780B4041B6AE18B3141F95613E.jpg[/IMG]
DaddyKnuck
May 25, 2019 07:46 AM
bra$$monkey
Feb 15, 2011 11:25 AM
torkrollin
Oct 27, 2009 06:02 AM
bullseye
Dec 29, 2008 03:29 PM
2007fxdc
Apr 1, 2008 08:39 PM
