Brake light stuck
Old Apr 17, 2008 | 11:15 AM
Sarge82's Avatar
Sarge82
3rd Gear
Default Brake light stuck
Have a 06 BOB, light is stuck. Craked both bleeder and check both levers to make sure they are not stuck. Also pulled fuses and unhooked them. Anyone run into this problem. I am sure its a short but have no idea where to start at...........thanks
Old Apr 17, 2008 | 11:27 AM
albanynyharleyrider's Avatar
albanynyharleyrider
Default RE: Brake light stuck
Had that happen to me. There was gap between the right grip switch housing and the front brake lever where the two meet on the handlebar. I Loosen the torx screws and slid one end down so they met. The brake light went off. Hope this makes since. Drove me crazy trying to figure out what was wrong.
Old Apr 17, 2008 | 11:34 AM
The Baron's Avatar
The Baron
Could be the brake switch in the right handcontrol or it could be the rear switch. Did you try unpluggin the two wires from the rear switch to see if the brake light went out?
Old Apr 17, 2008 | 11:36 AM
CSA's Avatar
CSA
Have you tried another bulb?
Old Apr 17, 2008 | 12:07 PM
dyna07custom's Avatar
dyna07custom
rear switch is always suspect 1
Old Apr 17, 2008 | 12:45 PM
AmericanIron's Avatar
AmericanIron
I would say its the switch in the handle bar. That is a very poor setup in my opinion.
Old Apr 17, 2008 | 01:22 PM
Sarge82's Avatar
Sarge82
3rd Gear
Thanks albanynyharleyriderthat did the trick, just needed some diffrent eyes I guess.
ruckus4offroad
Mar 23, 2014 08:59 PM
cnewty
Jun 23, 2007 01:29 AM
Beeracuda
Jul 24, 2006 05:58 PM
SIDEWAYZ50
May 23, 2006 08:32 PM
rlzachary
Jun 8, 2005 10:51 AM
