Air cleaner / stage 1 / for what use
Old Apr 22, 2008 | 03:50 AM
kuleli's Avatar
kuleli
Default Air cleaner / stage 1 / for what use
Sorry for my poor knowledge but would like to learn what is stage 1? I have se slip's on. What else should I replace to reach stage 1.....
Besides, can someone advise me the part number for air cleaner fits for 2006 WG.
Thanks in advance
Old Apr 22, 2008 | 04:21 AM
Ribcracker's Avatar
Ribcracker
Default RE: Air cleaner / stage 1 / for what use
stage 1 is an air filter and exhaust pipes and the fueling and igniton set up to match them.
Any of the harley air filters will work. But if you plan on going further in the future I sugest you look at a Force winder for year engine. They have been shown to work beter than the harley ones performance wise.
Old Apr 22, 2008 | 06:32 AM
kuleli's Avatar
kuleli
But I would like to have a performance air filter. I searched through hd website but could not found SE air filter that fits to 06 dynas
Old Apr 22, 2008 | 10:21 AM
coastrider's Avatar
coastrider
Look in the Screamin Eagle section of the 08 HD catalog. You will find a stage one ac that will fit your 06 Dyna. Runs about $140 and you can use either the round cover, which you have to purchase, or the stock football. Good Luck.
Ride Safe.
Old Apr 22, 2008 | 11:00 AM
2007fxdc's Avatar
2007fxdc
Stage 1 is the 1st level significant performance upgrade you can do to your bike - hence the term Stage 1. It involves higher flowing air cleaner, higher flowing exhaust, and for fuel injected bikes, some form of modification to the fuel management in the bike's computer to add more fuel to compensate for the additional air flow in and out. There are countless combinations of the 3 elements you can use to achieve stage 1 performance. My components are listed below in my sig. You have choices of air cleaners, pipes or slipon mufflers, and fuel management/tuner devices. The bike will "breathe" better and, therefore, run better and at a higher level of performance (i.e. throttle response and run cooler with the correct fuel mix).
The HD Screamin Eagle kit part number you are looking for for '04 - '07 dynas (EFI) is 29773-02C. The cost is $139.95. However, other companies make stage 1 air cleaners including Arlen Ness and K&N among others. The others and perhaps even the SE kit can be purchased for less online.
Old Apr 22, 2008 | 03:11 PM
vandykemc's Avatar
vandykemc
+1 on what 2007fxdc said. I followed advice I got on the forum and put the Screemin Eagle a/c kit, Vance and Hines Big Shot Stagganrds and Vance and Hines Fule Pak on my 07 Street Bob. I got the SE a/c from Cole H-D in Bluefield Wv $139.95 , the pipes $459.00 and fule pak $209 from American Motorcycle Classics on e-bay. I have read that some forum members have had issues with AMC, but I had everything I ordered on the phone in a week.
[IMG]local://upfiles/51694/763A80FEFCB1457E94F0C9002B749D0E.jpg[/IMG]
[IMG]local://upfiles/51694/307553EAA3A0433D81ECE821C796453C.jpg[/IMG]
Old Apr 24, 2008 | 04:13 AM
kuleli's Avatar
kuleli
Thank you very much indeed. You all great.... So 29773-02c is ok for me. When I bought the bike I only put se II slip's on and dealer made the calibration. This year I will buy se a/c and stage 1 will be completed.
my best regards
06 wg
Old Apr 24, 2008 | 04:23 AM
kuleli's Avatar
kuleli
It's me again!! I just called HD dealer here in Istanbul and they said they do not know how to install se a/c on my 06 dyna ????? It sounds crazy !!! As a last favor someone pls write down step by step if possible
Old Apr 24, 2008 | 08:35 AM
trevd's Avatar
trevd
Doesn't know how to install an air cleaner??? My Wife could probably even do that!
You need to find a new dealer...
Old Apr 24, 2008 | 08:51 AM
Airborne350G's Avatar
Airborne350G
It is super easy and comes with all the instructions. Being that they said they do not know how, then how would they tune the bike for it? Sinc eyou already increased the outflow of spent gas with the slip ons adding an air cleaner that flows more air you will be running real lean and could possibly burn up a valve or piston if it is not tuned correctly.
