CLUTCH QUESTION
Old Apr 23, 2008 | 04:11 PM
harley50's Avatar
harley50
Default CLUTCH QUESTION
When im at a stoplight. Bike in gear clutch lever pulled all the way in its still wants to move forward. Is that normal? I have to hold front brake in to keep it from moving. Whats up with that?
Old Apr 23, 2008 | 04:14 PM
07bobber's Avatar
07bobber
Default RE: CLUTCH QUESTION
YOU NEED TO ADJUST IT IF IT WANTS TO KEEP MOVING......
Old Apr 23, 2008 | 04:27 PM
harley50's Avatar
harley50
HOW?
Old Apr 23, 2008 | 05:21 PM
DougsDyna's Avatar
DougsDyna
Do you have a manual? Step by step in the service manual.
DougJ
Old Apr 23, 2008 | 07:51 PM
Topspin's Avatar
Topspin
ORIGINAL: DougsDyna
DougJ
Dealer... they'll do it free. Let them show you how much play you'll need for future reference.
Old Apr 25, 2008 | 02:07 PM
jfm5's Avatar
jfm5
have you sorted that clutch.. if not let me know i will help you with this problem..........
Old Apr 25, 2008 | 02:16 PM
harley50's Avatar
harley50
NOT YET. I DONT HAVE A MANUAL ,BUT A STEP BY STEP WOULD BE NICE THANKS
Old Apr 25, 2008 | 05:16 PM
moosh's Avatar
moosh
should have at least 1/8 inch free play at lever if not follow your clutch cable down the frame you will find a rubber cover pull it down and loosen cable so that you will have 1/8 inch of play..
Old Apr 25, 2008 | 05:19 PM
Lone Watie's Avatar
Lone Watie
had same problem couple weeks ago, in addition to having trouble hitting neutral. Clutch was out of adjustment - easy fix, 15-20 minutes tops. +1 on service manual, or see this post for step by step:
https://www.hdforums.com/fb.asp?m=3089711
good luck
Old Apr 26, 2008 | 03:07 PM
harley50's Avatar
harley50
THANKS TO ALL FOR THE HELP.
Dravenj
Jun 30, 2011 12:31 PM
Costnsg
Feb 28, 2009 08:56 PM
bikecop40
Aug 27, 2007 02:49 PM
Larryc5079
Jul 2, 2007 11:03 AM
dan69co
Jun 2, 2007 09:01 AM
