Turn signal relocation?
Old Apr 27, 2008 | 08:10 PM
YellowHawk's Avatar
YellowHawk
Default Turn signal relocation?
I'm a little confused about this....if I buy detachable sideplates for a sissy bar for my 06 FXDI, do I need the read turn signal relocation kit to install it? I don't have saddlebags or anything installed back there now.
Old Apr 27, 2008 | 08:50 PM
YellowHawk's Avatar
YellowHawk
Default RE: Turn signal relocation?
[align=left]I used the search function and I think I found my answer.
[/align][align=center] [/align]
Old Apr 27, 2008 | 09:09 PM
soup48's Avatar
soup48
If you have found the answer of being yes you do. Then go do it.
Old Apr 27, 2008 | 09:11 PM
YellowHawk's Avatar
YellowHawk
That's the answer I thought I found. Thanks for confirming that!
Old Apr 27, 2008 | 09:24 PM
RAWHIDE07's Avatar
RAWHIDE07
YES,not a big deal $75
Old Apr 27, 2008 | 09:38 PM
slaminum69's Avatar
slaminum69
yellowHawk,
I had the similair question a few weeks ago, I didnt want to move the TS to the rear with the license plate and post a question on the forum a couple of guys game up with a good set up to where the TS stay in the same location just extended out enough to fit the detachable set up, I bought the kit but I have not installed it yet. Here is the links hope this helps you.
https://www.hdforums.com/m_3247471/tm.htm
https://www.hdforums.com/m_3258921/tm.htm
Old Apr 28, 2008 | 05:32 AM
jmpancoast's Avatar
jmpancoast
Right now, you have the rear turn signalmounting bolt going through one hole in your strut and the turn signal wiring going through another hole, just in front of the mounting hole.
The relocation kit doesn't really relocate your signals. It just provides a round, hollow stalk used for moutning the signal and feeding the wiring through. This way, the signals only use the most rearward of the two holes in the strut. The detachable sideplates can now attach on the docking bushings on the new stalks. Adecorative plateis included which covers teh now vacant front hole.
Old Apr 28, 2008 | 06:26 AM
dyna07custom's Avatar
dyna07custom
ORIGINAL: jmpancoast
+1 jmpan has the answer
swagner25
Jul 3, 2013 06:56 PM
nefdez
Jan 6, 2013 01:42 PM
bharvey60
Jun 11, 2008 05:43 PM
olddude48
May 12, 2008 11:36 PM
deuce31
May 25, 2006 02:20 AM
