wide glide risers vs. street bob risers
Old May 3, 2008 | 08:25 PM
bobby5's Avatar
bobby5
Default wide glide risers vs. street bob risers
I was at the dealer and saw a wide glide and looked at the risers they look like there a inch taller then a street bobs. I was wondering if theyll fit a street bob cause i want a set that is 1" taller and fit stock clamp.
Old May 3, 2008 | 08:44 PM
twofish's Avatar
twofish
Default RE: wide glide risers vs. street bob risers
07 SB stock risers are 2”.
If that’s any help?
I put 3” risers on my SB see below link:
https://www.hdforums.com/m_3099943/tm.htm
Old May 3, 2008 | 08:50 PM
bobby5's Avatar
bobby5
Yeah i was wondering what stock wide glide risers are? If there taller would they fit on a street bob?
Old May 3, 2008 | 09:38 PM
twofish's Avatar
twofish
bobby5
What year Wide Glide?
I know they changed the SB risers in 08.
Old May 3, 2008 | 10:31 PM
mud's Avatar
mud
ORIGINAL: bobby5
bobby, WG risers will fit 06 07 StrBob, but,
keep this in mind -
StrBob bars are 1 inch diameter,
WideGlide bars are 1 1/4" diameter.
mud
Old May 3, 2008 | 10:40 PM
SURFOR Chop's Avatar
SURFOR Chop
ORIGINAL: mudpuddle
Bobby, WG risers will fit '06 '07 StrBob, but,
keep this in mind -
mud
So, guess you'll have to convert to the FXDWG bars too!! [They're the same height, aren't they Mud?]
Come to think of it, though: do FXDWG bars have the reduced 1" OD sections at the riser mount? Many phat bars do. If so, you could still use the risers with your FXDB bars.
Priest
[IMG]local://upfiles/29151/16D7883F18B743B19A085BC51884BA3F.jpg[/IMG]
Old May 3, 2008 | 11:34 PM
mud's Avatar
mud
ORIGINAL: Priest
ORIGINAL: mudpuddle
keep this in mind -
mud
Priest
Priest, the WG bars are the same height, yes.
No, they do not neck down to one inch in the riser area.
I went with WG inch and a quarterbars/risers on my 06 SuperGlide.
mud...............
Old May 3, 2008 | 11:54 PM
SURFOR Chop
I figured you'd know, Mud ... looks PHAT man!
Old May 4, 2008 | 10:19 AM
bobby5's Avatar
bobby5
How tall are 06 up wide glide risers?
Old May 4, 2008 | 10:21 AM
bobby5's Avatar
bobby5
Im looking for a set of risers that look think like the wide glide factory risers that are a inch taller and will fit the stock HD clamp. Where can i find a pair of these?
