Gremlin Bell
Old Jun 20, 2008 | 02:45 PM
cfdcaptain99's Avatar
cfdcaptain99
Default Gremlin Bell
What is the best location for a Gremlin bell on a Dyna? I got one from a friend. I'm not real wild about having it on the bike, but she keeps asking if I have it on yet and&nbsp\\;I don't want to be disrepectful.
Old Jun 20, 2008 | 02:50 PM
ratt196635's Avatar
ratt196635
Default RE: Gremlin Bell
i have mine hanging&nbsp\\;right below the voltage regulator
Old Jun 20, 2008 | 02:52 PM
Topspin's Avatar
Topspin
I have mine in a hole on the frame just below the fork neck and&nbsp\\; about a foot above the voltage regulator. Looks good there.
Old Jun 20, 2008 | 03:00 PM
sbchero's Avatar
sbchero
2nd Gear
ORIGINAL: Topspin
I have mine in a hole on the frame just below the fork neck and&nbsp\\;\\\\\\; about a foot above the voltage regulator. Looks good there.
&nbsp\\;
same spot here.&nbsp\\;
Old Jun 20, 2008 | 03:01 PM
Sammi's Avatar
Sammi
ORIGINAL: ratt196635
i have mine hanging&nbsp\\;\\\\\\;right below the voltage regulator
&nbsp\\;
&nbsp\\;
+1
&nbsp\\;
Sammi
Old Jun 20, 2008 | 03:03 PM
SK8ROD's Avatar
SK8ROD
i would place it on the ground just in front of the rear tire, then pull away hard
Old Jun 20, 2008 | 03:08 PM
8541hog's Avatar
8541hog
I would tell you where I have mine, but someone decided they liked it more than I do and it has dissapeared. But there is a small hole in a bar&nbsp\\; on the front of the frame as others have described that works just fine.
Old Jun 20, 2008 | 03:09 PM
hk_shooter's Avatar
hk_shooter
Mine's at where the rear brake pedal and the linkage rod meet.
Old Jun 20, 2008 | 03:14 PM
NELS's Avatar
NELS
Although I like sk8rod's answer I don't think it would make the ol happy!
Old Jun 20, 2008 | 03:31 PM
SciFiGuy's Avatar
SciFiGuy
ORIGINAL: sbchero
ORIGINAL: Topspin
I have mine in a hole on the frame just below the fork neck and&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; about a foot above the voltage regulator. Looks good there.
&nbsp\\;\\\\\\;
same spot here.&nbsp\\;\\\\\\;
&nbsp\\;
Yep that's where mine is located also.
