Possible leak?
Old Jul 1, 2008 | 09:36 PM
dbcoooper's Avatar
dbcoooper
Default Possible leak?
Hi guy's,
&nbsp\\;
I am posting a few pictures of a possible oil leak.&nbsp\\; The area I am noting is in between tranny and cylinder head. The seam at the&nbsp\\;T(you can see a dark patch)&nbsp\\; Note the oil is not hitting the floor because this particular leak is on the top of the motor.&nbsp\\; It resembles moisture but is an oilly substance.&nbsp\\; I noticed it a couple of days ago, washed the area real good/degreased and it was completely dry. Went for a ride and the dampness returned.&nbsp\\; I am just wondering if this is a big problem.
DB
Old Jul 1, 2008 | 09:37 PM
dbcoooper's Avatar
dbcoooper
Default RE: Possible leak?
pictures are not posting here goes again...
&nbsp\\;
&nbsp\\;
Old Jul 1, 2008 | 10:04 PM
dbcoooper's Avatar
dbcoooper
3rd finally!!
[IMG]local://upfiles/64007/F489D403E89945F1B79621DD49AB1DF0.jpg[/IMG]
Old Jul 1, 2008 | 10:09 PM
dbcoooper's Avatar
dbcoooper
The area on this picture that I am refering to is in the center of the picture and about a half inch up dark patch by the t gasket seams.&nbsp\\; Thanks to all who take the time...
&nbsp\\;
DB
Old Jul 1, 2008 | 11:02 PM
SFD_207's Avatar
SFD_207
Did you check your oil, and was it low?
Old Jul 1, 2008 | 11:12 PM
dbcoooper's Avatar
dbcoooper
Yes oil checked okay... keep in mind this is a very small area seams like a kinda seapage but not a whole bunch.&nbsp\\; Resembles moisture around that T seam/gasket.
&nbsp\\;
Thanks again.
Old Jul 2, 2008 | 01:22 AM
LownBlue's Avatar
LownBlue
It could just be oil blow-by coming from the air cleaner. Is there any oil
accumulation on the bottom of your air cleaner?
Old Jul 2, 2008 | 04:10 AM
Gaffy52's Avatar
Gaffy52
Had it on my '07 Bob after around 18 months - its most likely a blown crankcase seal behind the rear cylinder.&nbsp\\;\\\\\\; My dealer, under warrenty, had to strip and rebuild the engine and renew the center silicone seal.&nbsp\\;\\\\\\; Apparently its a known and common fault on the newer dynas.&nbsp\\;\\\\\\; Clean it all off with some brake cleaner on a rag and then go for a blast.&nbsp\\;\\\\\\; If its there when you get back you'll need to get it in to your dealer for repair.&nbsp\\;\\\\\\; Looks like a very thin patch of misted oil and dust.&nbsp\\;\\\\\\; Been fine ever since I had it done.
Old Jul 2, 2008 | 06:19 AM
mud's Avatar
mud
ORIGINAL: dbcoooper
The area on this picture that I am refering to is in the center of the picture and about a half inch up dark patch by the t gasket seams.&nbsp\\;\\\\\\; Thanks to all who take the time...
&nbsp\\;\\\\\\;
DB
DB, couldnt tell from your picture.
Does it look like this............
Old Jul 2, 2008 | 09:01 AM
dbcoooper's Avatar
dbcoooper
Mudpuddle that is exactly what it looks like!&nbsp\\;
ORIGINAL: mudpuddle
ORIGINAL: dbcoooper
The area on this picture that I am refering to is in the center of the picture and about a half inch up dark patch by the t gasket seams.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Thanks to all who take the time...
DB
