I did a stage 1 with the Vance & Hines Pro Pipe BP and I really like it. They are not cheep and a lot
of guys don't like 2 int 1 exhaust systems. This set up gives good results performance wise but
it is loud. It is as loud a my friends Short Shots. Good luck with the noise and you are going to
love your new ride.
I went with the Vance and Hines Big Shot Staggered and quiet baffles.
I havent run it with the standard baffles , .
I got lucky and bought them off a HD FORUM Member at a good price .
I also added the Power Commander and Screami Eagle AC .
My Dyna LOW RIDER sounds great , It has a very deep tone and mellows out on the road .
It also runs cooler and a lot smoother now ,
Good luck on your decision I no from experiance its a hard one to decide .
Thanks! much appreciated...I will let you know how I made out.
Any advice on pipes?
I prefer the Vance and Hines Long Shots but that's just a preference. I'm holding out on getting them 'till I can get my FXDL back to stock height again. No reason to buy new chrome just to scrape it up in the turns.
When new the belt is "seating" itself,simply clean it while on the sidestand with a toothbrush and a hose and the noise will go away,you may need to do it a couple of \\;times \\;to remove all the residue.
ORIGINAL: biggron
I got the same thing or should say HAD .Its the belt making the noise .try alittle armoral on the belt .Dont spray it all just wipe it on and you will stop that noise .I used w-d 40 on mine then my son who works for harley said armoral is better
