Raked tree cups?
Old Jul 2, 2008 | 07:30 PM
greenstreetbob's Avatar
greenstreetbob
Default Raked tree cups?
Anyone running raked tree cups? Is 3 degrees even enough to tell a difference in the rake? I know Traveler has them and his bike had a great rake, but I don't want to switch over to a Wide Glide front end or spend $500 to also do custom raked trees. Will the 3 degrees from the cups be noticeable and will they interfere with the ignition switch/lock?
Old Jul 2, 2008 | 08:49 PM
wiegs's Avatar
wiegs
Default RE: Raked tree cups?
I have been looking for the same thing. Seems like know one has really used raked cups (except softail guys). I am planning to purchase some cups&nbsp\\;for my 07 lowrider. It will put my&nbsp\\;total rake&nbsp\\;at 4.5 degrees, which will put the rake close to the stock softail standard and duece.&nbsp\\; I think you will be able tell the difference with just 3 degrees. I know you can tell the difference going to wide glide trees and that is only 2 degrees. &nbsp\\;Cups are a lot cheaper option then new trees. And it is safer! I read somewhere that one downside to raked cups is it spreads your trees apart about 1 inch. I don't think that is a big deal.&nbsp\\; Here is a link to the cups I am looking at. I spoke to a guy at vulcan and he said this set will work except newer dyna's require a longer stem. They do have them and will ship with the set, but you must specify when ordering.
&nbsp\\;
http://vulcanworks.net/Fork-Cup-Set-...ers-p-417.html
Old Jan 22, 2012 | 05:24 AM
Bahama Yellow's Avatar
Bahama Yellow
I'm also thinking about it. Did you do it yourself in the end? How did it go?
Old Jan 22, 2012 | 09:45 AM
97dyna's Avatar
97dyna
Default +1 on Vulcan Engineering - This is 3 degrees
Old Jan 22, 2012 | 08:48 PM
Bahama Yellow
Looks great, I'll contact Vulcan to see whether they got something for the Fat Bob. No issues in ride quality? And did you need to drop the rear shocks by half an inch to compensate?
Old Jan 22, 2012 | 08:51 PM
Jackie Paper's Avatar
Jackie Paper
What keeps them from turning? How much does 3 degrees lower the front?
Old Jan 22, 2012 | 10:19 PM
sgmfiser's Avatar
sgmfiser
Wonder how these would look on a Wide Glide??
Pops
Old Jan 23, 2012 | 04:07 AM
onemyndseye's Avatar
onemyndseye
They are pressed into the frame neck
Old Jan 23, 2012 | 06:24 AM
Dingobob's Avatar
Dingobob
Actually you just hammer them into the neck they won't move very tight fit.
I had them on my street bob, prob lowered the front end about 2inches but I had 10" shocks on the rear and it was fine with stock forks. You do need a press to swap the neck stems though.
They did the job but I didn't really like the way it spread the distance between the top and bottom trees. As for handling it was better than stock with 10" shocks.
I ended up chopping and raking my neck which I think is better but a lot harder and more expensive
Old Jan 23, 2012 | 09:17 PM
Bahama Yellow
Yes, cutting the frame up is the only right way but a big operation too.
That's a lot of drop, 2 inches. I'd then replace the rear shocks too.
I wrote to Vulcan and asked them whether they have cups for a Fat Bob and how much drop I should expect. So far, no response. If I get a response, I'll let you know.
