uh oh!!!!
Old Jul 11, 2008 | 02:21 PM
rounder's Avatar
rounder
Default uh oh!!!!
my front cylinder breather hole is stripped.... unscrewed the breather bolt and out came some threads... now what do I do.... I remounted, bathed the bolt in 243 loctite and tightened it down as much as it will let me without slipping loose again...
how do I fix this???
Old Jul 11, 2008 | 02:25 PM
JRK5892's Avatar
JRK5892
Default RE: uh oh!!!!
you can get a thread repair or you may have to try to re thread it, i would try to do this first with the stock thread pattern, make sure it goes in STRAIT...
Old Jul 11, 2008 | 02:40 PM
rounder's Avatar
rounder
like this? http://www.timesert.com/
looks easy enough... now, what size do I need, and do I need to take the head off to do this?
Old Jul 11, 2008 | 03:01 PM
rounder's Avatar
rounder
http://www.acehardware.com/product/i...id=body_rv_img
this might be even beter won't have to buy a tap etc....
never really run into a stripped thread so this is new to me .... had no idea this stuff existed
Old Jul 11, 2008 | 03:06 PM
overhead's Avatar
overhead
I did something similar and a thread chaser worked for me.&nbsp\\;
Old Jul 11, 2008 | 03:22 PM
domenicp7's Avatar
domenicp7
Re-tap&nbsp\\;will probably be better than the stock thread.&nbsp\\;
Old Jul 11, 2008 | 03:54 PM
rounder's Avatar
rounder
ORIGINAL: domenicp7
Re-tap \\\\\\;will probably be better than the stock thread. \\\\\\;
won't a thread tap change the size of the hole to no longer accept the breather bolt
Old Jul 11, 2008 | 04:55 PM
domenicp7's Avatar
domenicp7
An ordinary tap and die can also be used for repairing threads in stripped holes or bolts. Die nuts are dies made for cleaning up old threads, they have no split for resizing.&nbsp\\; This is how I repaired&nbsp\\; few problems I have incountered and not changed the stock bolt.&nbsp\\;
mesamark5
Apr 12, 2021 09:27 AM
huyrua
Jul 30, 2013 09:44 AM
Delphox
Exhaust System Topics
Oct 7, 2011 04:38 PM
ssbogger
Jun 2, 2008 12:50 PM
Motown_HOG
Sep 27, 2007 12:27 AM
