I have a dyna wide glide with the orange frame kit to lift my bike.
It seems the Sears yellow lift does not lift level. \\; \\; Is this normal?
This front tire rasies off the ground first and the rear wheel takes several pumps before it moves off the ground. \\; The lift looks realitively stable but the angle freaks me out.
It seems the Sears yellow lift does not lift level. \\;\\\\\\; \\;\\\\\\; Is this normal?
This front tire rasies off the ground first and the rear wheel takes several pumps before it moves off the ground. \\;\\\\\\; The lift looks realitively stable but the angle freaks me out.
The two front adapters go right in front of the pegmounts.
Ok I have moved the front adaptors back and repositioned the jack.
It is still leaning slightly to the rear according to my level. \\;\\\\\\; I suppose this is normal.
you can see the slight bend to the rear if you look close. \\;\\\\\\; \\;\\\\\\; I have the front 'orange blocks' against the jiffy stand mount.
if you think theres something wrong with the jack go and take it back....honestly all u need to do is strap it down with some tie downs and that bitch aint going nowhere
