? about new air filter
Old Jul 16, 2008 | 09:05 PM
hddave2's Avatar
hddave2
Default ? about new air filter
i have the SE air filter kit on my 06 dyna..i have about 9000 miles on it so im thinking its time to replace.. should i go back with a SE filter element or is there a better flowing filter element&nbsp\\;\\\\\\;that will work with the SE back plate..im only wanting to replace the filter only...thanks
Old Jul 16, 2008 | 09:09 PM
Bluesssman's Avatar
Bluesssman
Default RE: ? about new air filter
K&N filter. Good for a million miles. Can be cleaned and reused over and over!
Old Jul 16, 2008 | 09:10 PM
itileman's Avatar
itileman
If it's the oiled filter, all you should have to do is clean and re-oil&nbsp\\;it. K&amp\\;N makes a cleaning kit.
Old Jul 16, 2008 | 09:14 PM
8541hog's Avatar
8541hog
The kit should clean and oil&nbsp\\;several times, I clean mine about every 2500 miles. Quick and easy to do.
Old Jul 16, 2008 | 09:15 PM
PigInaBlanket's Avatar
PigInaBlanket
The SE air filter from HD does not need oiling and you can clean it.
Old Jul 16, 2008 | 09:16 PM
hddave2's Avatar
hddave2
the filter i have came with the se kit when i bought the bike. i dont know if its the filter that uses oil to clean it.. i would like a better flowing filter if there is one that flows better than what i have..
Old Jul 16, 2008 | 09:24 PM
8541hog's Avatar
8541hog
Always thought the SE was KandN ... My bad
Old Jul 16, 2008 | 09:47 PM
TOMMAY's Avatar
TOMMAY
K&amp\\;\\\\\\;N part number HD0800 is a good replacement for the paper filter. Ordered mine from AutoZone for less than thirty bucks. It comes pre oiled but you'll need to buy the cleanin/oiling kit when it gets dirty.
&nbsp\\;
Good Luck
&nbsp\\;
Tom
Old Jul 16, 2008 | 10:14 PM
rounder's Avatar
rounder
K&N for sure!!!
Old Jul 16, 2008 | 10:44 PM
PigInaBlanket
The SE filter that fits our bikes hddave 2 is a non oiled type that can be cleaned in the sink and air dried. I did the same for my Sportster I used to have. The SE filter for the Sporty had problems and came apart after a while. Not sure if the big twin filters have that same problem as no one is talking about it like they did for the Sporsters.
