Clunk washer fix
Old Jul 18, 2008 | 09:21 AM
carltex's Avatar
carltex
Default Clunk washer fix
Can anyone tell me the ID, OD, and thickness of pn 45727-08 steering head washer. HD Dallas would have to order and don't want to drive to HD Dallas. I can just make one at work.
Old Jul 18, 2008 | 09:32 AM
JRK5892's Avatar
JRK5892
Default RE: Clunk washer fix
unless you know how to adjust your fall away you may want to go up there to have them do it... i pick up my washer after work
Old Jul 18, 2008 | 10:00 AM
carltex's Avatar
carltex
Got the manual, checked and adjusted the fallaway (3 1/4"), drove it checked again. Did this a couple times before I got the method down. The dealer didn't even know of this bulletin about the washer. If they parts orders it its a toss up if they will call you when it comes in or not.
Old Jul 18, 2008 | 10:36 AM
JRK5892's Avatar
JRK5892
I will measure mine for you before i put it on brother... it will be later prob around like 7 or 8
Old Jul 18, 2008 | 10:51 AM
carltex's Avatar
carltex
I'm a machinist by the way. No hurry, appreciate the help.
Old Jul 18, 2008 | 10:56 AM
blkfalc4's Avatar
blkfalc4
Yep, you can make one at work but the hardness of the new part is different. How can you guess the rockwell?
Old Jul 18, 2008 | 11:01 AM
carltex's Avatar
carltex
Good question but anything has to be better than that paper washer it came with, even if I didn't harden it all. I think it's a thicker washer isn't it? Just went and checked and the original is only .030" thick. Could have at least made it .060".
Old Jul 18, 2008 | 11:07 AM
JRK5892's Avatar
JRK5892
from what i am told it is just thicker, they still bend it up. so i do not belive that it is hardened... the do bend it up dont they? i will ask
Old Jul 18, 2008 | 11:32 AM
carltex's Avatar
carltex
Could this be another loctite item? Pretty much all it is is a jam nut and the washer is to keep it from turning.
Old Jul 18, 2008 | 11:44 AM
hrchdog's Avatar
hrchdog
The washer didn't fix my clunk, now dealer says they may have to tear apart the fork tubes to find the clunk, gonna need the bike for a few days to find the clunk.
