Swapping Tins
Old Jul 27, 2008 | 01:47 PM
firefighter3666.'s Avatar
firefighter3666.
1st Gear
Default Swapping Tins
Can anyone point me to step by step directions for swapping tins on my FXDBI?
Old Jul 27, 2008 | 01:51 PM
SC-Longhair's Avatar
SC-Longhair
Default RE: Swapping Tins
front fender...remove 4 bolts. tank...remove two bolts and disconnect wires underneath dash and disconnect crossover fuel line under frame and quick disconnect fuel line. Rear fender...remove 4 bolts.&nbsp\\;
Old Jul 27, 2008 | 02:06 PM
firefighter3666.
1st Gear
Ok. I guess I asked for that. What's it take to swap the guts of the tank?
Old Jul 27, 2008 | 02:15 PM
firefighter3666.
1st Gear
Tanks dented, planning on replacing it. Thinking of taking the opportunity for custom paint. I appreciate the help.
Old Jul 27, 2008 | 02:16 PM
Smiley51's Avatar
Smiley51
Fire I did it. I went from a FXD to a FXDB. It's not hard but you WILL need the manual. Disconnect the fuel line before you lift the tank off very important. The pump and filters are a little tricky to get out. I changed handle bars at the same time and ran wires internally just take your time.
Old Jul 27, 2008 | 03:44 PM
mud's Avatar
mud
front fender easy. 4 bolts.
align carefully before final tighten on install.
Old Jul 27, 2008 | 03:45 PM
mud's Avatar
mud
Rear fender. Remove tailight.
Wires have to come out of the fittings.
(explained here - https://www.hdforums.com/fb.asp?m=2711998 )
Pull the main wiring through conduit
then back thru the new fender.
Careful, dont overtighten the four fender bolts on reinstall.
etc
Old Jul 27, 2008 | 03:48 PM
mud's Avatar
mud
the
Old Jul 27, 2008 | 03:51 PM
mud's Avatar
mud
site
mud's Avatar
mud
forked
Yogie
Feb 1, 2016 03:43 AM
High Roller
Mar 14, 2015 07:07 PM
Alain
Feb 9, 2015 08:13 AM
TexFF
Sep 28, 2011 10:50 AM
Wonkaboy
Oct 28, 2009 07:33 AM
