Leaking Primary.
Old Jul 31, 2008 | 12:48 AM
marcss's Avatar
marcss
Default RE: Leaking Primary.
My dyna was also leaking from the primary bearing seal. They ended up replacing the bearing too, which went out once at around 7,500 miles 20k on my '06 fxdwg now
Old Jul 31, 2008 | 04:48 AM
Helitrash's Avatar
Helitrash
3rd Gear
Replacing the bearing seal cost 350.00.&nbsp\\;\\\\\\; Hopefully its the grommit on the drain plug.&nbsp\\;\\\\\\; If not F-it.
Old Jul 31, 2008 | 04:50 AM
Helitrash's Avatar
Helitrash
3rd Gear
I got 18k mikes.
Old Jul 31, 2008 | 05:05 AM
Helitrash's Avatar
Helitrash
3rd Gear
I asked the parts guy.&nbsp\\; I will put permatex on every gasket.
Old Jul 31, 2008 | 10:04 AM
GRCLowrider's Avatar
GRCLowrider
6th Gear
I'm told that the inspection cover tower gaskets could cause a primary leak also. If you didn't replace them, you might try doing so. I put in new ones, but still have a similar leak on my 03 Lowrider. Didn't cure my issue but maybe it will cure yours. If it's&nbsp\\;350 bucks to replace the&nbsp\\;bearing seal, I'll say F*** it and live with the minor leak for now.
stephtell
EVO
24
Jun 11, 2016 09:56 AM
tombeving
Jan 6, 2013 09:19 PM
Whiffleboy
Jul 24, 2011 11:57 AM
hoodlum
Aug 12, 2008 05:50 PM
cewood
Feb 26, 2008 07:52 AM
