Rear Suspension..Better Ride
Old Aug 5, 2008 | 07:50 AM
harleyram's Avatar
harleyram
Default Rear Suspension..Better Ride
Hey all, need some help or recomendations on rear suspension. I have an '06 Superglide. I replaced the front suspension with 1 inch lower progressive springs and the rear shocks with '06 Lowrider units. My problem is the bike rides very rough..stiff. I don't want to trade this bike in on a touring bike. Now that I have a back injury, from a drunk driver, I need a softer ride. I originally lowered this bike because of my size, 5-7. I went on a 300 mile ride the other day and on some bumps the entire bike came off the ground! I have a Corbin solo and tried an Airhawk cushion on top. Seemed to help a little with the minor bumps. Thanks in advance for all help and suggestions!
Old Aug 5, 2008 | 07:54 AM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: Rear Suspension..Better Ride
You don't have to trade your Dyna in on a touring bike just trade in your shocks.The air shocks off an Electraglide or Road King will bolt right up.
Old Aug 5, 2008 | 08:00 AM
0ut1aw's Avatar
0ut1aw
might play with the preload on your shocks a bit too&nbsp\\; less preload should give a softer ride aka lightest setting on the shocks
Old Aug 5, 2008 | 08:46 AM
kk6pg's Avatar
kk6pg
The air shocks will make your back a happy camper
Old Aug 5, 2008 | 10:06 AM
rounder's Avatar
rounder
the preload could be too soft causing you to bottom out the shock for a very rough ride over bigger bumps....I would adjust first then determine if a new set of shocks are in order...
Old Aug 5, 2008 | 10:56 AM
timberwolfz28's Avatar
timberwolfz28
road king and superglide shocks are longer arent they?
Old Aug 5, 2008 | 11:22 AM
JRK5892's Avatar
JRK5892
you can get lower version from eastern performance, as seen in my sig pic
Old Aug 5, 2008 | 11:34 AM
harleyram's Avatar
harleyram
Thanks guys, never thought of Roadking shocks. I played with the preload adjustments, just didn't seem to make a difference. Although Roadking shocks will probably be cheaper, anyone tried Airnott Suspensions?
6 gun
Sep 11, 2018 06:39 PM
Street06
Nov 26, 2012 05:35 PM
Crissie
Screamin Eagle CVO Models
Mar 17, 2011 07:05 PM
JohnE
Jul 12, 2009 05:02 PM
dsuppa
Aug 29, 2006 08:07 PM
