No highbeam
Old Aug 29, 2008 | 09:49 PM
amish's Avatar
amish
Default No highbeam
my highbeam dosn't work anymore.low still works. is ther a fuse to the highbeam or something?
tried a new bulb same thing. would it be the wiring then?
i did my own install of my apes had to problem but just theother day the highbeam stoped working. could it be the actual headlight?
let me know if you have any info/suggestion on this problem
Thanks
Old Aug 29, 2008 | 09:53 PM
maddghost's Avatar
maddghost
I' would be checking the connection to the switch ,which you must have had to deal with at some point during install.
Old Aug 30, 2008 | 10:12 AM
pennetta's Avatar
pennetta
Why did you replace the first one? I would try another bulb, again. The circuit is pretty simple.
Old Aug 30, 2008 | 11:09 AM
0ut1aw's Avatar
0ut1aw
I had an issue like this just this week
I notice you have replaced the bars
If you spliced your wires when you did the bars check those splices. If the splice has come lose for the HB then your switch wont work anymore. Check the wiring where it plugs into the bulb. Are all the connectors connecting?
Could be the switch but most likely not. It is a simple on off circuit. Like a home light switch. No fuse or anything I know of.
Old Aug 30, 2008 | 02:20 PM
JRK5892's Avatar
JRK5892
my bet is the bulb man... happens
Old Aug 30, 2008 | 03:21 PM
dope_man_21's Avatar
dope_man_21
If you had to add wire or splice into the factory wiring I would check the voltage at the switch, ( I'm sure there still voltage there) and check for voltage at the plug on the headlamp, (I bet there's none or extremely low voltage) thus indicating an open circuit in the wiring. If it has worked since you changed the bars I would be will to bet that it was vibration that has caused the wiring to loosen in one of the connections, I would always solder the wires together where the might get wet, moved or are under vibration.
Crossbones
Jun 24, 2012 07:31 PM
reecenos
Aug 9, 2011 09:29 AM
trslim
Jul 29, 2009 04:55 AM
kdietz
Sep 17, 2007 07:09 AM
pingj
11
Mar 30, 2005 11:59 PM
