Cold weather storage
Old Sep 10, 2008 | 02:40 PM
jake40ma's Avatar
jake40ma
Default Cold weather storage
I will be picking up an 09 Fat Bob in October. Living in the Boston area I'll probably only get a good month out of it before the snow flys. I am going to have to store this bike offseason in an unheated shed. Are there any precautions I should take beforehand? I know I should probaly put stabilizer and a little dry gas in the tank but any suggestions would be appreciated Thanks
Old Sep 10, 2008 | 02:57 PM
JRK5892's Avatar
JRK5892
you have to have somethign down under it... keep that moistue from rising up... few boards down and some carpet will do it... spray the bikes metal down with WD40 to keep it from rusting, put something in your exhaust pipes to keep the mice out of it, mouth ***** and some charchole under you bike... moth ***** will keep the mice out, charchole (regular old grill stuff) will absorb the moisture with all the temp changes so that moisture does not accumulate (I put down a paper plate on my seat and put them on it for my other bikes that used to store in the shed) move the bike and start it about 1 time every 2-3 weeks to prevent flat spots... i would sugest removing the battery and keeping it in a dry enviroemnt NOT ON CONCRETE or it will ruin the battery... you can get a cheap cover that will work great at wallmart get the XL the biggest one they offer... if you have a paper air filter i would also remove this as well and use a towel to stuff into your throttle body... all this may seem like a bit of over kill, but take it frm me... sucks to come out to your bike and hav it as a rats nest! i had a 3 bikes while living at my dads house he only let me keep 2 in the garage with his...so i had to put on in the shed... it was DESTROYED from mice and rust... i do not live in the contry either... (chicago) next year i did the above and it was just like how i left it come spring! fired right up! ooh ya if you hit your 1000 mile, i would wait till the spring to do your service, or else you will have to just swap out the brand new fluids you put in now in the spring cause moisture will build up in your motor from sitting... hope this helps
Old Sep 10, 2008 | 03:16 PM
sonic's Avatar
sonic
Great info from JRK5892, makes me glad to live down here! We ride all 12 months of the year. Winter riding is a blast, never any snow and it's not so dam hot.
Old Sep 10, 2008 | 04:07 PM
gunner11's Avatar
gunner11
Just about the same for Eastern New Mexico, only 1 or 2 bad months.
Old Sep 10, 2008 | 05:14 PM
Splatter's Avatar
Splatter
Just for the record, there are ridable days every single month in the Boston area. There might only be a few in January or February, but there are always some. (Ridable meaning above freezing and dry pavement.) Just sayin...
Old Sep 10, 2008 | 06:02 PM
glide05's Avatar
glide05
I agree - brought mine home at the end of 05.
Put 800 miles on between Jan and April.
Above freezing and dry roads works for me (sun helps).
Old Sep 10, 2008 | 06:26 PM
ziggy's Avatar
ziggy
Leave the battery in an use a Battery Tender Jr. They keep the battery at full charge,I have been using mine for 5 years.Keep the battery terminals clean and you should be fine.Look at BatteryTender.com.
Old Sep 10, 2008 | 06:56 PM
Drat's Avatar
Drat
I have a J&S Jack that I use for maintenance and cleaning during the year. I pull the battery and put the bike on the jack for winter storage. I got a deal on an HD cover that keeps the dirt off but still breathes. No tire flat spots and I just roll it out in the spring and change the fluids, toss in the battery, and I am off and running.
Old Sep 10, 2008 | 07:43 PM
IrishHarleymin's Avatar
IrishHarleymin
I am curious, when you say spray the metal with WD40 do you mean you can spray everything, chrome engine, bolts and frame???
franktko
Sep 24, 2014 02:23 PM
rsarno
Aug 30, 2013 12:14 PM
cldiver
Oct 15, 2011 08:46 AM
Krazy8s
Oct 21, 2010 11:50 AM
Shadofaxx
Sep 22, 2006 04:56 PM
