remove backrest on wide glide ?
Old Mar 26, 2006 | 03:24 AM
maurino17's Avatar
maurino17
6th Gear
Default remove backrest on wide glide ?
hey everyone,
I am new here, just bought an 03 wide glide !
I would like to remove the backrest but it looks like the bracket runs on the inside of the fender rails, what fills that space if you remove the backrest ?
thanks
Old Mar 26, 2006 | 09:08 AM
jv225's Avatar
jv225
Default RE: remove backrest on wide glide ?
I had the same question a few weeks ago. Check out the replies here https://www.hdforums.com/m_317340/mp.../tm.htm#317340
Old Mar 26, 2006 | 12:46 PM
maurino17's Avatar
maurino17
6th Gear
thanks so much man, i thought for sure harley had some special part !
I actually would like to have one detachable. . . .
what does that invlve ?
any idea ?
thanks
Old Mar 26, 2006 | 12:57 PM
jv225's Avatar
jv225
Sorry I haven't put a detachable one on but I can't imagine it being very hard to do. Maybe someone who has done it can give you a tip or two.
Old Mar 30, 2006 | 12:37 PM
jcsantis's Avatar
jcsantis
2nd Gear
It involves buying the detachable backrest kit, plus another kit that are the plates to fill that space you mentioned. Also, the signal lights are relocated, and changed (backrest's back end attaches to the signal light mounts), so you do have to cut the signal light wiring and re-atach. Hope this helps
Jack Russell
Oct 4, 2012 10:41 PM
1HD1C
Jun 7, 2011 10:30 AM
n.o.yat
Dyna Parts
11
Aug 11, 2010 02:18 PM
tnelsmn
Sep 12, 2008 11:55 PM
FlashG
Aug 28, 2005 01:40 PM
