View Poll Results: This is what I would do:
I would buy the Thundermax-in the long run it's worth it.
24
85.71%
I would buy a less expensive tuner because....
10.71%
I would leave the bike stock, it isn't worth the money.
3.57%
Voters: 28. You may not vote on this poll
Thundermax - is it worth it?
Old Nov 14, 2008 | 09:10 PM
marinepilot81's Avatar
marinepilot81
1. Bought mine from the forum member Shooter64 and was the cheapest I found. Contact him on here or http://www.catseyecustoms.com/.
2. It's simple to install, tinker with, set up. If you can't figure it out, the customer service guys have been top notch.
3. I IMMEDIATELY noticed a difference the first time I rode the bike after my TMAX install. It ran much smoother and the power band was cleaner. I'd recommend it for sure.
Old Nov 15, 2008 | 05:38 AM
rounder's Avatar
rounder
did you have a tuner on their previously?
Old Nov 15, 2008 | 06:37 AM
r0de_runr's Avatar
r0de_runr
I put a TMax on my 07, but went with a TTS Mastertune on my 09.
1. TTS is available now.
2. TTS allows you to tune your bike yourself without a dyno, using their V-Tune program. While riding, no guesswork or seat-of-the pants tuning.
3. TTS is about $425 delivered from Doc1.
4. Like the TMax, the TTS shows you all the settings in a table and allows you to edit everything.
5. TTS saves your stock map, to be later re-installed if you need to.
6. TTS uses the stock Harley ECM.
Old Nov 15, 2008 | 07:27 AM
armybrat02's Avatar
armybrat02
Originally Posted by mywideglide
I am now starting to think about pipes, air cleaner and tuner. I am finding in the Balt. Md area, the Thundermax is going for $900. WOW!
1.) Slip Ons- about $270
2.) Stage 1- about $150
3.) Thundermax- about $ 900
4.) Installation- God Only knows- I bet it's between $400 to $500.
I am told, not only will I hear the difference but I will feel the difference in performance.
What I want to know: Is the Thundermax worth the extra money? Why or why not.
Even if I go with the HD tuner to save money, is it worth it.
Install yourself and save the few hundred bucks. Search around and find the best price and know that now or right after to holidays is the best time to buy because of sales. Look for the sales and buy then. Get the tuner that works for you I like the pcIII because its easy for me to do myself. I got mine for about $220 ( i dont remember where right now, if I can find it i will let you know.) Look at the net and find a place that wants your business that does prive matching that works great as well.
Good Luck and ride safe
Steve
Old Nov 15, 2008 | 11:04 AM
marinepilot81
No, I had the stock ECM. A friend and I did it at the same time and both had immediate results.
Old Nov 15, 2008 | 11:29 AM
masterblaster's Avatar
masterblaster
Any impact om MPG?
Old Nov 15, 2008 | 12:07 PM
marinepilot81
Originally Posted by masterblaster
Any impact om MPG?
If there was, it was insignificant. I averaged 45-50 the entire time I was in NC. Here in Hawaii I get 35-40.
Old Nov 15, 2008 | 01:31 PM
last saint's Avatar
last saint
The Thundermax is top notch and I highly recommend it. Simply said...it kicks ***!!
D
Old Nov 16, 2008 | 04:53 AM
Eddie4Harley's Avatar
Eddie4Harley
From: Holland (with the wooden shoes and windmills)
I put the Tmax on my '07 SB about a year ago, together with Samson StreetSlashers and a Big Sucker.
I love it, the more I ride, (AutoTune) the better it gets!
Also the bike runs much cooler (temp) too!
Because of our Ecc Emision Laws in Europ, the bikes are verry lean adjusted (from factory) and running verry hot at normal riding conditions.
First when I came home from a one our drive, the bike was ticking in the garage for a half hour or so, with the Tmax I hear nothing.
That gives you an idee how significant it helps!
Old Nov 16, 2008 | 08:28 AM
creekhed1's Avatar
creekhed1
I'd love a T-Max but for the money I'll go with a PCIII From Jamie at FuelMoto. I had one for my Sporty and it was sweeeet and under $300
PC Novice
Milwaukee Eight (M8)
32
Jun 2, 2019 08:10 AM
kylebru1
May 19, 2015 04:05 PM
MLZ
Apr 28, 2014 09:32 PM
Reindeer
Jul 9, 2012 06:45 PM
TO34
Mar 22, 2010 07:18 AM
