Harbor Freight Motorcycle Dolly Question
Old Sep 30, 2008 | 07:14 AM
ehretja's Avatar
ehretja
Default Harbor Freight Motorcycle Dolly Question
Any of you guys use the motorcycle dolly from Harbor Freight with your Dynas? If so, am I correct in assuming that you'd also need to use the lift adapters on the dolly as well as the lift (meaning a second set of adapters would be needed). If anyone is using it...how well does it work? I'm looking for something to allow me to store the bike for the winter and keep it up off the tires and also at the same time i'm hoping to tear apart the front end to powder coat and this would give me a good platform to work off of.
Any feedback is appreciated.
Jeff
Old Sep 30, 2008 | 09:42 AM
tommyjeeps's Avatar
tommyjeeps
Default Dolly question
I have the dolly and it works great. I am able to push my bike up close against the garage wall, letting me pull my car in the garage. The dolly only makes it easier to move around, does not lift or keep the tires off the ground.
Old Sep 30, 2008 | 10:24 AM
Shark46's Avatar
Shark46
I have the inexpensive (yellow) one, and it works great! I get both wheels off of the ground and it is OK to work on. For long term or to move it around I would strap it to it.
Old Sep 30, 2008 | 10:43 AM
Rodney's Avatar
Rodney
I saw a harbor freight lift this weekend and looked much better than the one I got from Shucks. the safety catch lever mechanism is much better than mine. the one thing I don't like about the harbor one was the foot pump lever is to close to the release lever and its easy to push the release while operating the pump. It worked great lifting the Dyna I just got just had to be careful where to position the pads. Dropping the oil may be more of hassle since the lift covers that area.
Old Sep 30, 2008 | 11:19 AM
wkdavistx's Avatar
wkdavistx
I change my oil with the bike on the kickstand.
Old Sep 30, 2008 | 06:33 PM
ehretja's Avatar
ehretja
I think you guys may have misunderstood my question. By dolly I meant the thing that you use your jack to lift the bike up and then slide the dolly under the bike (and thus not needing the jack). Here is the link for what i was referring to
http://www.harborfreight.com/cpi/cta...emnumber=94778
Old Sep 30, 2008 | 08:52 PM
Rodney's Avatar
Rodney
Oh!
I got to have one or 2 of those!!
Old Oct 1, 2008 | 06:56 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default I use them and have several of them.
I use them all of the time but you are going to need to have a cherry picker to pick up your bike to set it on. HF has a collapsible one (cherry picker) which you can always buy on sale for $150. a very good tool I use all of the time. Please check this dolly out on one of my DIY pages here. In this case I need to lift the bike up higher on my tble for needed working clearance. In this and many other cases these really pay for themselves. $35 is no money
M4i2k2e2
Apr 22, 2019 09:22 AM
druski
2014-2024 Touring Models
Feb 28, 2015 04:29 PM
Ronp42
Mar 9, 2013 11:10 AM
sunsetdriver
Mar 16, 2011 08:09 PM
edilgdaor
May 18, 2007 03:35 AM
