Can someone explain to the novice how to interpret the print out?
I just left the bike at the shop for a heavy breather, SERT and the "custom" mapping. What can I expect or should I expect? Based on my knowledge of tuners I assume I will get quickness and torque, anything for the top end?
If you look at Mupuddle's sheet you'll see two separate runs on the dyno. The first run is before his tune which are the red lines, with torque and hp indicated respectively on the graph. You have the RPM indicated on the bottom and hp and torque along the left wich produces the power curve of hp and torque as the bike goes through the rpms.The blue lines is his dyno run after his bike was tuned. You'll notice on with the run with the blue lines that he picked up 10 hp and torque after his tune. Also he has awesome low to mid-range torque, which is where most people want it. He also has gobs of HP on the top end.
By no means am I an expert so others chime in if I'm horribly wrong.
