Installing forward controls?
Old Oct 15, 2008 | 08:22 AM
Goddahavit's Avatar
Goddahavit
Thumbs up
Sweet, that’s the exact info I was looking for, thanks les63
I didn’t want to cut the shaft in case my wife inherited the street bob,
I am assuming the kury phone number is on the web?
Old Oct 15, 2008 | 11:21 AM
les63's Avatar
les63
Not a problem, Leslie! The anti-rattle clip is item number 400455
($8.95/each) and the "Beauty Cap" is item 9072 ( $10.99/each). Please
contact us directly to order as item 400455 is not available online.
Thank you!!!
Mike Jury
Kuryakyn Customer Care
454 County Road VV
Somerset, WI 54025-9031 USA
866-277-9598, Extension #103
Fax: 715-247-5007
Just call customer care and press the number for sales when prompted.
Les
On another note, the HD kit is $349.00 + the Kury kit is $399.00, but on ebay the kury kit is $299.00 free shipping fron Eastern Performance, the kit says 2006 and up, I called Kurt tech support and they said will bolt right up to a 2009, this kit has all the parts needed. I would have bought it except I got 20% discount on parts for 90 days from my dealer. Kury kit # is 9063 Dyna foward controls.
Old Oct 15, 2008 | 12:35 PM
Gwjvw's Avatar
Gwjvw
I m 6'2'' and bought the 3in extended, and i could use a 4in if they made them!
Old Oct 15, 2008 | 12:47 PM
Goddahavit's Avatar
Goddahavit
Yes, the Kury kit is cheaper but I actually want the Black ones, and only affordable ones I find are the HD set, for 06 and up, 280 + ship on the bay as well as zanotti's (spelling?)
I used to have the +2 inchers on my custom softail, so I was looking for the same +2 for the dyna, only ones I can find are the custom chrome ones on ebay...
I am thinking +3 is a little long as Im just under 6 ft...
and thanks to WS6 thats a ton of great info in 1 spot
Old Oct 28, 2008 | 05:16 PM
Goddahavit's Avatar
Goddahavit
Les63, did you not use the Shift Arm Retainer for ‘06-up Dyna?
I ordered the parts listed above, but I guess im missing how to install the anti rattle clip?
thinking i got the wrong retainer?
any help?
Thanks, Eric
Ohh snap, I see they have a different instructions for the +3 inch forwards, apparently they have another part, that just screws into the mid shift lever to pinch it against the inner primary, never mind, I should have looked prior to ordering, could have just ordered that part...
Old Oct 28, 2008 | 05:44 PM
Herr Monk's Avatar
Herr Monk
...just buy some highway pegs and keep the bike fully-functional...
...too many emasculated Dynas out there already.
Old Oct 28, 2008 | 05:50 PM
les63's Avatar
les63
I did use the clip I do think it was the wrong one however but, it all worked out fine. See pictures. I did not use the beauty cap, just glued a live to ride sportie brake caliber insert over the hole in primary. If you use this method you will need a 5/16-24x1/2" bolt to attach the clip to the arm.
Les
[IMG][/IMG]
http://i437.photobucket.com/albums/qq95/les63/001.jpg
http://i437.photobucket.com/albums/qq95/les63/002-1.jpg
Old Oct 28, 2008 | 06:47 PM
Goddahavit's Avatar
Goddahavit
ahh, thanks, for the pic, that helped a lot.....
yea, not really liking the shape of the cap, im going to try and spray it black...
Old Jan 21, 2009 | 05:38 PM
gmpm5754's Avatar
gmpm5754
Question: I just purchased the HD Forward Control Kit, the Kuryakin anti-rattle clip and the "Beauty Cap". My question is when I install this beauty cap and tighten the set screw the shaft will still be sticking out of the case, do you then pull the shaft inward and install the anti-rattle clip on the backside? If so does the chrome cap become flush with the outer case or still stick out?
Thanks,
RT
Old Jan 21, 2009 | 06:50 PM
Goddahavit's Avatar
Goddahavit
I wound up not using the cap at all, I pushed the shift lever in and behind the bolt like the above pic, and used the retaining clip to hold it there.
I should eventually find a cover i like to cover it, but its good for now.
