Derby Cover Removal Question
Old Oct 27, 2008 | 12:19 PM
Low_Wider's Avatar
Low_Wider
Default Derby Cover Removal Question
Guys,
Sorry for the newbie question but am doing my own service the first time. Got the engine and tranny fluids replaced OK but am having difficulty getting the derby cover off. I'm using a Torx T25 socket which seems a bit loose but can't get the T30 in either. The bolts are not budging as I come close to what feels like stripping the head. With a torque wrench I'm getting about 100-110 in-lbs of torque before it feels like the socket is about to strip.This is about the recommended torque for install but I don't think I can go any higher without stripping the head of the bolt. So what am I missing? Wrong socket? Any and all suggestions appreciated except for the one that says the dealer probably used permanent Loctite when they did the last service.
Old Oct 27, 2008 | 12:26 PM
Big Poppa Pump's Avatar
Big Poppa Pump
You need a T27.
Old Oct 27, 2008 | 12:49 PM
Harley43147's Avatar
Harley43147
I just changed mine out. I believe it is a 27 torx.
Good luck.
Old Oct 27, 2008 | 01:06 PM
PigInaBlanket's Avatar
PigInaBlanket
Yes make sure you have the right torx. I ended up stripping a couple screws on my old Sportster derby cause of what you were just describing.
Old Oct 27, 2008 | 01:18 PM
rounder's Avatar
rounder
+3 you need a t27 torx.
Old Oct 27, 2008 | 01:29 PM
Technologist's Avatar
Technologist
+4 If no one has mentioned it yet, you need a T-27!
Old Oct 27, 2008 | 01:34 PM
JRK5892's Avatar
JRK5892
you will also want to use a punch and smack each bolt before trying to remove them, it will break loose the loc tite and prevent you from stripping it wiht your T27
Old Oct 27, 2008 | 01:43 PM
shimmon's Avatar
shimmon
damn t 27... i broke one about 3 weeks ago. it was not a craftsman but i wanted to repalce it with a craftsman. sears doesnt sell the t27 by itself. you have to buy this kit with the odd ball torx in it. so instead of 5-10 bucks i ended up spending 30-35 on that 4 piece torx set. wasnt happy with sears that day!
moral to the story is get a nice quality set, like craftsman that shouldnt break. but dont expect a new one when you take it to your local sears.
ohhh... and to top that off i had a broken craftsman ratch, went to have it replaced with new (like normal) and they wanted to rebuild it in the back! well i ended up telling them i use these tools for a living and there is no way i'm walking out with anything less than new... they replaced it for new this time! me = mad at craftsman for this dumb move!
Old Oct 27, 2008 | 03:25 PM
Low_Wider's Avatar
Low_Wider
Thumbs up Thanks
Guys,
Thanks for all the help and advise. I was concerned I'd get flamed for such a newbie question. This is why I love this forum, great advise from guys who have done a lot of work on their scoots and are more than willing to give straight up advise to help us all along.
Old Oct 27, 2008 | 04:53 PM
rockon's Avatar
rockon
Changed my derby out yesterday...as everyone else has said, use a T27 torx socket...a lot of people seem to have a helluva time getting the bolts loose, but mine were easy. I tightened them back down until they met solid resistance but not excessively, since those torx bolts are fragile. The service manual says to retorque them to between 84-108 inch lbs, but I don't have a 1/4" torque wrench.
