Dyna Low. Popping, Stalling, Jerking Forward
Old Nov 2, 2008 | 12:47 PM
pastafa's Avatar
pastafa
Stage II
Default Dyna Low. Popping, Stalling, Jerking Forward
While riding, my bike started popping, jerking forward and stalled. When riding in a high gear, 5th & 6th, the bike seemed to be running ok. When shifting to the lower gears and easing off the throttle is when the problem would occur. In addition, the bike was idling at an extremely high rate. Any ideas on what the problem could be?
Old Nov 2, 2008 | 12:56 PM
BONES206's Avatar
BONES206
What year....carb or FI? Where do you live..has the temp turned cold?
Could be an intake leak, and cold temps would make it worse.
Old Nov 2, 2008 | 01:04 PM
pastafa's Avatar
pastafa
Stage II
2006. FI. New York.
Old Nov 2, 2008 | 02:15 PM
Nevar's Avatar
Nevar
any MODS ? recent changes ? Good gas [ slim but a chance]
+1 for intake leak . Check for burned or loose wires on the sensors
Old Nov 2, 2008 | 02:21 PM
firefighter3666's Avatar
firefighter3666
I recently had a similar issue, it was due to the negative terminal coming loose at the battery. Harley tech at the dealership told me it's not uncommon due to the vibrations. I now carry a phillips screwdriver and a 10mm wrench with me everytime I ride.
Old Nov 2, 2008 | 02:59 PM
robzuc97's Avatar
robzuc97
Any DTC's? Occur after a gas fill?
Old Nov 2, 2008 | 04:33 PM
rounder's Avatar
rounder
drop of blue loctite will work too.
Old Nov 2, 2008 | 04:36 PM
rounder's Avatar
rounder
first to check would be your battery connections. Sounds like the problem occurs when the bikes vibrations are increased.
Old Nov 2, 2008 | 08:44 PM
PigInaBlanket's Avatar
PigInaBlanket
Mine kept coming loose also until I used some blue loctite. No more problems.
Old Nov 2, 2008 | 09:07 PM
firefighter3666
Even with the locktite I still had an issue. The tech at the dealership told me it was likely because I had the battery tender connected between the bike cable and the battery. He said that the difference in metals of the two connectors causes some expansion and retraction. Thus, overcoming the locktite. Moved the cables around and I'm hopeful, but still carrying the tools.
