I just got married on Halloween!!!! My lady is pretty damn cool!!
you got that right!
best thing I can tell you is detatch the brake line from the triple tree(botton allen bolt). Then with cardboard inserted in the lever remove from bars and place on ground keeping it upright. This will avoid you from needing to bleed the brakes(found out hard way).
you do not need to remove tank but I would remove tank bolts , lift tank, and move it back a few inches for easier access to your panel underneath for the wiring.
you will not need to remove grips or switches (just loosen the throttle switch to remove brake portion).
good luck and hope to see pics soon. I've torn down my front end twice; once to black out the lower legs and triple trees... I tore it down recently to install my inverted front end. It's really not that hard plus given the great advice here, I'm sure you will have no problems at all
What's wrong with bikes and living rooms?That's why i gave my ol'lady a $40,000 kitchen so she'll stay out of my livingroom,which is precisely where she belongs anyway.
